Set jack settings via terminal
hello guys!
how can I set up the default soundcard settings via terminal?
i tried: sudo Patchbox-config jack config --card get_cards
but then I’m just in the Patchbox settings for choosing a device but I haven’t chose one.
so I need an command to choose my USB Device directly via terminal.
Can someone help?
Thanks in advance
A command like this should work:
patchbox jack config --card hw:1,0 --rate 48000 --buffer 512 --period 3
Get the list of cards by running aplay -l.
woahh perfect! it works thanks you so so much!
