Hello you all,
I’m running the newest version of Patchbox OS on my raspberry 4b. I’m using the Sabrent USB Externe Soundkarte as a soundcrad to use a mic for puredata.
I want to start pd and the jack with autostart so my patch can start immediately after boot. So I created a file in lxsession to start the Jack while boot. The problem is, that it says all the time after boot: Jack: couldn’t connect to server, is Jack running?
when I check the status of the jack it runs. While setting up wizard I chose my usb audio device as default soundcard but every time I reboot the settings aren’t saved and set back to “Headphones bcm2835_headpho” and not on “usb device”. I think thats why pd can’t connect to the jack. (after I connected the usb device, the jack is connecting with pd)
So my question is:
How can I set the settings via terminal so I can include the command in the autostartfile. Or how ca I keep the settings saved to have the Usb device as a default soudcard?
I’m really looking forward to your responds and thank you very much for your help!
I’m really struggling
