Jack won't start on my RP4
I have a newly installed version of Patchbox OS on my Raspberry Pi 4. However, I can’t get any sound out of either the AV or the HDMI port. When investigating this matter, by running sudo systemctl status jack.service, I get the following messages, with the word failed showing up in red:
● jack.service - JACK Server
   Loaded: loaded (/lib/systemd/system/jack.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2021-10-07 13:09:16 BST; 5h 13min ago
  Process: 401 ExecStart=/etc/jackdrc (code=exited, status=255/EXCEPTION)
 Main PID: 401 (code=exited, status=255/EXCEPTION)
Oct 07 13:09:16 patchbox jackdrc[401]: creating alsa driver ... hw:pisound|hw:pisound|128|2|48000|0|0|nomon|swmeter|soft-mode|16bi
Oct 07 13:09:16 patchbox jackdrc[401]: control open "hw:pisound" (No such device)
Oct 07 13:09:16 patchbox jackdrc[401]: ALSA lib pcm_hw.c:1822:(_snd_pcm_hw_open) Invalid value for card
Oct 07 13:09:16 patchbox jackdrc[401]: ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture-only mode
Oct 07 13:09:16 patchbox jackdrc[401]: Cannot initialize driver
Oct 07 13:09:16 patchbox jackdrc[401]: JackServer::Open failed with -1
Oct 07 13:09:16 patchbox jackdrc[401]: Failed to open server
Oct 07 13:09:16 patchbox systemd[1]: jack.service: Main process exited, code=exited, status=255/EXCEPTION
Oct 07 13:09:16 patchbox systemd[1]: jack.service: Failed with result 'exit-code'.
Even after trying to start Jack, using jack_control start, I still get the same error.
Any ideas?
You should reconfigure Jack, run patchbox and enter jack submenu.
Thanks for the suggestion. I’ve launched patchbox and tried just about every option possible there. What is it, more specifically, that I’m trying to achieve here?
patchbox → jack → config, configure the audio card.
Make sure you use the correct size of audio buffers, based on recommendations on Setup Wizard - Patchbox OS Documentation - if they’re too low, Jack won’t start up.
