How to update / upgrade to the latest 64bits version?
Hi here,
What is the way to update patchbox os to the latest raspberry pi os ? (trixie 64 bits ?)
The Patchbox OS does not yet have a Trixie build. Raspberry Pi OS does not support ‘dist upgrades’, the normal way is to make backups of important files, and starting fresh by flashing the newer OS version.
If you need to use Trixie software, you can use Raspberry Pi OS image and add our APT server:
curl https://blokas.io/apt-setup.sh | sh
Then you can install our software packages you need.
Thanks a lot for this fast answer ! :slight_smile:
I will let you know how I upgrade my pisound stuff ! :slight_smile:
