hello community,
is it possible to set the last values of a volume pedal for example 127 into a cc64 command like a damper switch?
regards
b.t
hello community,
regards
b.t
Give us a bit more detail please, @Bilo_2022,
like if such a pipeline were possible, what would go into it and what would come out?
(For example, I could imagine what you’re asking for being just a mapping where the set property just stays the same until you next move the pedal…
…but i guess you mean more than that)
hello resonotter,
this time it’s quite simple cc7 pedal value 127 equals sustain damper on and back to value 126 equals sustain damper off again.
regards
b.t
So what gets sent to switch the “sustain damper”?
on the bottom i put the input but only when value 127 comes in.
and this sould the output.
regards
b.t
Two Transforms, like this?
and
