Converting incoming note velocity to corresponding cc value
Is there a way to do this? I seem to be missing it. I am thinking back to the old Yamaha TX81Z that had a drum with a filter connected to the velocity that was very expressive to play. I would like to try to apply that too… Everything!
By default, the Transform pipe is configured to do exactly that. :slight_smile: Just place it where the notes are and you’ll get CC #3 with velocity values.
wow, I did not know that. Then I can transform CC3 to CC 74, for example for filters or whatever. Thanks so much for your response!
Or just change the 3 in Argument 1 to 74, so it comes out as CC #74 right from the start. :slight_smile:
