Hi, could you allow synced delay time to be set to zero? The reason is I’m trying to use the delay effect as an “offset” for notes. At the moment I have to have the delay set to 100% dry for “0” offset, or I have to change the delay time AND the mix to 100% wet to get an offset. This is not really practical when I’m doing the offsetting live from a controller.
Also on the same topic, having shuffle / swing for delay and not just repeater would be cool.
