hello
i want to propose OFFSET parameter with ±64 steps for CC LFO pipe,
it will allow to move DEPTH range up and down the 128 steps spectrum using only one parameter and thus
only one MAP is needed
bests
K
hello
bests
K
So, by OFFSET you mean the ability to change where midpoint or centre-value is? ie. OFFSET from 64.
I can see the sense in this but AFAI can see the LFO Pipe is one of those that is “maxed” out; that is all 11 bytes are already being leveraged  to yield  the properties LFO already has.
So, it would only be possible if other changes meant an overhaul to give each pipe say 12 bytes.
yes exactly what i meant
got it
thanks
