Pypisoundmicro import error
I’m trying to read an encoder in Python following the docs here. This is my script (perhaps there are mistakes in there, but for now I need to get over the basic error of importing the pypisoundmicro module):
#!/usr/bin/env python3
import pypisoundmicro as psm
from time import sleep
enc = psm.Encoder.setup(psm.ElementName.randomized(),
                        psm.Pin.B03,
                        psm.PinPull.UP,
                        psm.Pin.B04,
                        psm.PinPull.UP)
while True:
    try:
        print(f"enc val: {enc.get_value()}")
        sleep(0.5)
    except KeyboardInterrupt:
        exit()
When I run it, I get the following:
  File "/home/patch/Scripts/./enc_test.py", line 3, in <module>
  File "/usr/lib/python3/dist-packages/pypisoundmicro/__init__.py", line 1, in <module>
    from .element import Element
  File "/usr/lib/python3/dist-packages/pypisoundmicro/element.py", line 1, in <module>
    from .swig import pypisoundmicro as psm
ImportError: cannot import name 'pypisoundmicro' from 'pypisoundmicro.swig' (/usr/lib/python3/dist-packages/pypisoundmicro/swig/__init__.py)
Any ideas?
Thank you for the report, this was a .deb packaging bug when rebuilding for Debian trixie - I have just released a fix, available from pypisoundmicro version 1.0.1-3.
To get the fix, do:
sudo apt update
sudo apt install pypisoundmicro
Doing sudo apt update gave me this:
E: Release file for http://deb.debian.org/debian-security/dists/bookworm-security/InRelease is not valid yet (invalid for another 2d 8h 57min 13s). Updates for this repository will not be applied.
E: Release file for http://deb.debian.org/debian/dists/bookworm-updates/InRelease is not valid yet (invalid for another 2d 19h 23min 14s). Updates for this repository will not be applied.
E: Release file for http://archive.raspberrypi.com/debian/dists/bookworm/InRelease is not valid yet (invalid for another 1d 5h 2min 0s). Updates for this repository will not be applied.
sudo apt install pypisoundmicro returned that it is installed in the latest version. I guess it’s related to the above errors. I’ll have to wait a couple of days, according to the error?
BTW, have you release a PatchBox OS based on Trixie?
My bad, forgot to make the bookworm build, will release it soon.
There’s no Patchbox OS build based on trixie yet, but all our packages are built and published for trixie, so one could start from a trixie lite or desktop image and install the missing bits.
Btw, the error you saw about the time - probably the time of the Raspberry Pi did not sync to the network just yet by the time you ran sudo apt update, so it understood the contents incorrectly. In case you see such error again, check the system time using date -R
The fix is now available for bookworm too.
