This is a companion discussion topic for the original entry at https://blokas.io/patchbox-os/docs/Modules/
I used the command patchbox module install to install the sine-module
but it failed and I’m unsure what this means
E: Repository ‘http ://raspbian.raspberrypi.org/raspbian buster InRelease’ changed its ‘Suite’ value from ‘stable’ to ‘oldstable’
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
E: Repository ‘http ://archive.raspberrypi.org/debian buster InRelease’ changed its ‘Suite’ value from ‘testing’ to ‘oldstable’
Manager: /usr/local/patchbox-modules/imported/sine-module directory deleted
Error: sine-module.module installation failed
Try running:
sudo apt-get update --allow-releaseinfo-change --fix-missing
And retry the previous command.
You might want to mention this fix on the startup guide if this is related to the release of Bullseye. Was troubleshooting without finding this and I had to re-flash my SD card. Only on the second rebuild did I find this thread. Looks like I’m finally moving again.
The sine wave module is outputting what’s almost a 440 Hz tone, but it’s off; I’d say it’s around an F4 (349.228 Hz).
I’m using the Pi’s onboard headphone jack with the recommended configured settings. There’s also a rhythmic pulsing sound and an extremely high-frequency pitch, it might be picking up noise from the microprocessor or something.
Just for your perusal/my own interest!
The built-in jack on Pi is based on a PWM wave and is inaccurate and with audible noise, especially if you reduce the volume in alsamixer. Best to get a dedicated audio card. ![]()
Gotcha, I seem to recall reading something about how the differing mains voltages between NA and the UK might account for at least part of the PWM noise?
I was planning on grabbing a Pisound either way, but using the headphone out makes for a very compelling marketing campaign, haha
Cheers!
The sine-module example seems broken
patch@patchbox:~ $ patchbox module install https://github.com/BlokasLabs/sine-module
fatal: destination path 'sine-module' already exists and is not an empty directory.
Manager: sine-module.module is valid
Manager: sine-module.module prepared for installation
Manager: sine-module.module install script found: /usr/local/patchbox-modules/imported/sine-module/install.sh
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
Hit:5 http://apt.blokas.io bookworm InRelease
Reading package lists... Done
E: Unable to locate package jack-sine
patch@patchbox:~ $
Rpi4, fresh install of the latest image, patchbox version 1.4.0. Running apt-get update and apt-get install jack-sine directly yields the same result. Suggestions?
