I am trying to get the HiFiBerry DAC+DSP running on an RPI4. The trick part seems to be the input, the output is working fine.
I followed:
1.
2.
change stuff according to:
https://www.hifiberry.com/docs/software/using-the-dac-dsp-to-record-audio-from-s-pdif/
there is the input hardware device visible in Jack but in order to route the input thru the dsp I need to install that that dsptoolkit to give commands to the dsp…and for this I need pip3
see
trying to install pip for python3 I get the errors below
maybe some linux geek can help to get pip3 running
thanks Falk
patch@patchbox:~ $ sudo apt-get install python3-pip
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following additional packages will be installed:
dh-python libexpat1-dev libpython3-dev libpython3.7-dev python-pip-whl python3-asn1crypto python3-cffi-backend
python3-crypto python3-cryptography python3-dev python3-distutils python3-entrypoints python3-keyring
python3-keyrings.alt python3-lib2to3 python3-secretstorage python3-setuptools python3-wheel python3-xdg
python3.7-dev
Suggested packages:
python-crypto-doc python-cryptography-doc python3-cryptography-vectors gnome-keyring libkf5wallet-bin
gir1.2-gnomekeyring-1.0 python-secretstorage-doc python-setuptools-doc
The following NEW packages will be installed:
python3-keyrings.alt python3-lib2to3 python3-pip python3-secretstorage python3-setuptools python3-wheel
python3-xdg python3.7-dev
0 upgraded, 21 newly installed, 0 to remove and 1 not upgraded.
Need to get 50.5 MB/51.0 MB of archives.
After this operation, 82.1 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 Index of /raspbian buster/main armhf libpython3.7-dev armhf 3.7.3-2+deb10u2
404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
Get:2 Index of /debian buster/main armhf python-pip-whl all 18.1-5+rpt1 [1,591 kB]
Get:4 Index of /debian buster/main armhf python3-pip all 18.1-5+rpt1 [171 kB]
Get:3 Index of /pub/linux/debian/raspbian/raspbian/ buster/main armhf python3-asn1crypto all 0.24.0-1 [78.2 kB]
Get:5 Index of /raspbian/raspbian buster/main armhf python3-cffi-backend armhf 1.12.2-1 [70.1 kB]
Get:6 Index of /raspbian/raspbian buster/main armhf python3-crypto armhf 2.6.1-9+b1 [251 kB]
Get:7 Index of /raspbian/raspbian buster/main armhf python3-cryptography armhf 2.6.1-3+deb10u2 [184 kB]
Err:8 Index of /raspbian buster/main armhf python3.7-dev armhf 3.7.3-2+deb10u2
404 Not Found [IP: 93.93.128.193 80]
Get:9 Index of /raspbian/raspbian/ buster/main armhf python3-entrypoints all 0.3-1 [5,508 B]
Get:10 Index of /raspbian/raspbian/ buster/main armhf python3-secretstorage all 2.3.1-2 [14.2 kB]
Get:11 Index of /raspbian/raspbian/ buster/main armhf python3-keyring all 17.1.1-1 [43.1 kB]
Get:12 Index of /raspbian/raspbian/ buster/main armhf python3-keyrings.alt all 3.1.1-1 [18.2 kB]
Get:13 Index of /raspbian/raspbian/ buster/main armhf python3-setuptools all 40.8.0-1 [306 kB]
Get:14 Index of /raspbian/raspbian/ buster/main armhf python3-wheel all 0.32.3-2 [19.4 kB]
Get:15 Index of /raspbian/raspbian/ buster/main armhf python3-xdg all 0.25-5 [35.9 kB]
Fetched 2,786 kB in 2s (1,176 kB/s)
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/libpython3.7-dev_3.7.3-2+deb10u2_armhf.deb 404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/python3.7/python3.7-dev_3.7.3-2+deb10u2_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
