I’ve received my Pisound today, along with the case and a Midihub, and eagerly put everything together just to find upon first startup that the Pisound isn’t detected (or, to be more precise, it seems to be detected but fails to initialise).
My setup is as follows:
Pisound Rev 2020 v1.1
Raspberry Pi 3B
Official Raspberry Pi PSU for the 3B (5V 2.5A)
Patchbox OS - I also ran apt update and upgrade just to be sure.
I’ve already tried all the steps mentioned in similar posts, but to no avail:
- Re-seating the GPIO pins (btw. I noticed the pins seem to be too short when using the spacers, so I’ve also tried it without them in place)
- Updating and upgrading Patchbox OS, even going as far as upgrading the Pi firmware
- Trying to flash the firmware via the Blokas-flavour avrdude, all I’m getting is:
sh: 1: echo: echo: I/O error
sh: 1: cannot create /sys/class/gpio/gpio8/direction: Directory nonexistent
sh: 1: cannot create /sys/class/gpio/gpio8/value: Directory nonexistent
avrdude: error: AVR device not responding
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override this check.
avrdude done. Thank you.
Please reboot your system now (sudo reboot). Thank you!
(Btw., I’m only getting the ‘Directory nonexistent’ errors when trying this via ssh, however avrdude’s output is the same when directly logging into the Pi) - I’ve also tried running sudo dtoverlay pisound. This returns:
* Failed to apply overlay '0_pisound' (kernel). Running avrdude afterwards results in the same output as above.
aplay -l lists the following devices:
**** Liste der Hardware-Geräte (PLAYBACK) ****
Karte 0: b1 [bcm2835 HDMI 1], Gerät 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Sub-Geräte: 4/4
Sub-Gerät #0: subdevice #0
Sub-Gerät #1: subdevice #1
Sub-Gerät #2: subdevice #2
Sub-Gerät #3: subdevice #3
Karte 1: Headphones [bcm2835 Headphones], Gerät 0: bcm2835 Headphones [bcm2835 Headphones]
Sub-Geräte: 4/4
dmesg returns:
[ 0.000000] Linux version 5.4.51-v7+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1331 SMP Fri Jul 31 16:45:56 BST 2020
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] Normal zone: 2133 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 242688 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920
[ 0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=720 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=3ac474d7-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 881512K/970752K available (8192K kernel code, 689K rwdata, 2552K rodata, 1024K init, 825K bss, 23704K reserved, 65536K cma-reserved)
[ 0.000000] ftrace: allocating 28275 entries in 56 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] random: get_random_bytes called from start_kernel+0x328/0x500 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000022] Switching to timer-based delay loop, resolution 52ns
[ 0.000290] Console: colour dummy device 80x30
[ 0.000871] printk: console [tty1] enabled
[ 0.000936] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000984] pid_max: default: 32768 minimum: 301
[ 0.001385] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001430] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002812] Disabling memory control group subsystem
[ 0.002935] CPU: Testing write buffer coherency: ok
[ 0.003515] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004469] Setting up static identity map for 0x100000 - 0x10003c
[ 0.004685] rcu: Hierarchical SRCU implementation.
[ 0.005381] smp: Bringing up secondary CPUs …
[ 0.006520] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007789] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.008938] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009089] smp: Brought up 1 node, 4 CPUs
[ 0.009177] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.009206] CPU: All CPU(s) started in HYP mode.
[ 0.009230] CPU: Virtualization extensions available.
[ 0.010306] devtmpfs: initialized
[ 0.026762] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.027065] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.027122] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.030253] pinctrl core: initialized pinctrl subsystem
[ 0.031460] NET: Registered protocol family 16
[ 0.035696] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.041974] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.042016] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.042274] Serial: AMBA PL011 UART driver
[ 0.044445] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.070108] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-07-31 17:08, variant start
[ 0.080120] raspberrypi-firmware soc:firmware: Firmware hash is cdd815a302e9462c15d4a0800f0d5d4741c2d81a
[ 0.131813] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.134048] SCSI subsystem initialized
[ 0.134324] usbcore: registered new interface driver usbfs
[ 0.134417] usbcore: registered new interface driver hub
[ 0.134563] usbcore: registered new device driver usb
[ 0.136517] clocksource: Switched to clocksource arch_sys_counter
[ 1.296619] VFS: Disk quotas dquot_6.6.0
[ 1.296764] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.296983] FS-Cache: Loaded
[ 1.297274] CacheFiles: Loaded
[ 1.308637] thermal_sys: Registered thermal governor ‘step_wise’
[ 1.309042] NET: Registered protocol family 2
[ 1.310115] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.310190] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.310330] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.310540] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.310725] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.310799] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.311112] NET: Registered protocol family 1
[ 1.311909] RPC: Registered named UNIX socket transport module.
[ 1.311941] RPC: Registered udp transport module.
[ 1.311968] RPC: Registered tcp transport module.
[ 1.311993] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.313778] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.317166] Initialise system trusted keyrings
[ 1.317448] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.329265] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.330105] NFS: Registering the id_resolver key type
[ 1.330169] Key type id_resolver registered
[ 1.330196] Key type id_legacy registered
[ 1.330232] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.331579] Key type asymmetric registered
[ 1.331609] Asymmetric key parser ‘x509’ registered
[ 1.331677] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.331714] io scheduler mq-deadline registered
[ 1.331741] io scheduler kyber registered
[ 1.337033] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.371513] Console: switching to colour frame buffer device 160x45
[ 1.386181] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1280x720
[ 1.391904] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.392614] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.393511] vc-sm: Videocore shared memory driver
[ 1.394152] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.407198] brd: module loaded
[ 1.419838] loop: module loaded
[ 1.421314] Loading iSCSI transport class v2.0-870.
[ 1.422407] libphy: Fixed MDIO Bus: probed
[ 1.422647] usbcore: registered new interface driver lan78xx
[ 1.428016] usbcore: registered new interface driver smsc95xx
[ 1.433100] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.166464] Core Release: 2.80a
[ 2.171423] Setting default values for core params
[ 2.176335] Finished setting default values for core params
[ 2.381625] Using Buffer DMA mode
[ 2.386421] Periodic Transfer Interrupt Enhancement - disabled
[ 2.391285] Multiprocessor Interrupt Enhancement - disabled
[ 2.396101] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.400939] Dedicated Tx FIFOs mode
[ 2.406358] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7504000 dma = 0xf7504000 len=9024
[ 2.411541] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.436371] dwc_otg: Microframe scheduler enabled
[ 2.436442] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.441325] WARN::hcd_init_fiq:458: FIQ ASM at 806d89f4 length 36
[ 2.446202] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ 2.451067] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.456002] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.461006] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ 2.465907] Init: Port Power? op_state=1
[ 2.470760] Init: Power Port (0)
[ 2.475859] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 2.480777] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.485656] usb usb1: Product: DWC OTG Controller
[ 2.490562] usb usb1: Manufacturer: Linux 5.4.51-v7+ dwc_otg_hcd
[ 2.495491] usb usb1: SerialNumber: 3f980000.usb
[ 2.501126] hub 1-0:1.0: USB hub found
[ 2.505980] hub 1-0:1.0: 1 port detected
[ 2.511460] dwc_otg: FIQ enabled
[ 2.511470] dwc_otg: NAK holdoff enabled
[ 2.511480] dwc_otg: FIQ split-transaction FSM enabled
[ 2.511494] Module dwc_common_port init
[ 2.511874] usbcore: registered new interface driver usb-storage
[ 2.516816] mousedev: PS/2 mouse device common for all mice
[ 2.522952] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.529843] sdhci: Secure Digital Host Controller Interface driver
[ 2.534437] sdhci: Copyright(c) Pierre Ossman
[ 2.539643] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 2.544986] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 2.550004] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.556664] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.561909] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.567002] usbcore: registered new interface driver usbhid
[ 2.571837] usbhid: USB HID core driver
[ 2.577739] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 2.584375] [vc_sm_connected_init]: start
[ 2.593752] [vc_sm_connected_init]: end - returning 0
[ 2.600594] Initializing XFRM netlink socket
[ 2.605350] NET: Registered protocol family 17
[ 2.610228] Key type dns_resolver registered
[ 2.615594] Registering SWP/SWPB emulation handler
[ 2.620755] registered taskstats version 1
[ 2.625240] Loading compiled-in X.509 certificates
[ 2.630261] Key type ._fscrypt registered
[ 2.634775] Key type .fscrypt registered
[ 2.649956] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.654660] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 2.661422] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.667773] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.672614] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 2.704017] sdhost: log_buf @ (ptrval) (f7507000)
[ 2.730674] Indeed it is in host mode hprt0 = 00021501
[ 2.810929] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.816150] random: fast init done
[ 2.821802] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.829210] of_cfs_init
[ 2.834205] of_cfs_init: OK
[ 2.839904] Waiting for root device PARTUUID=3ac474d7-02…
[ 2.846831] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.853160] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.860732] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.925309] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.934677] mmc0: new high speed SDHC card at address e624
[ 2.939395] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.944202] Indeed it is in host mode hprt0 = 00001101
[ 3.010047] mmcblk0: mmc0:e624 SU16G 14.8 GiB
[ 3.019076] mmcblk0: p1 p2
[ 3.054826] mmc1: new high speed SDIO card at address 0001
[ 3.067754] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.072556] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.078872] devtmpfs: mounted
[ 3.091529] Freeing unused kernel memory: 1024K
[ 3.096963] Run /sbin/init as init process
[ 3.186974] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 3.191806] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.197385] hub 1-1:1.0: USB hub found
[ 3.202243] hub 1-1:1.0: 5 ports detected
[ 3.526592] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.657009] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 3.661970] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.669797] smsc95xx v1.0.6
[ 3.761146] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:36:56:a3
[ 3.839069] systemd[1]: System time before build time, advancing clock.
[ 4.015758] NET: Registered protocol family 10
[ 4.022707] Segment Routing with IPv6
[ 4.059478] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.072014] systemd[1]: Detected architecture arm.
[ 4.160363] systemd[1]: Set hostname to .
[ 5.183619] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.208999] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.215024] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 5.228370] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.234457] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.256798] systemd[1]: Listening on Syslog Socket.
[ 5.269938] systemd[1]: Reached target Swap.
[ 5.283356] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 5.299683] systemd[1]: Created slice system-getty.slice.
[ 5.314001] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.218975] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.340845] systemd-journald[121]: Received request to flush runtime journal from PID 1
[ 7.047140] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.050729] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 7.050755] [vc_sm_connected_init]: start
[ 7.057266] [vc_sm_connected_init]: installed successfully
[ 7.081945] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.087921] mc: Linux media interface: v0.10
[ 7.095355] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 7.104286] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 7.154887] videodev: Linux video capture interface: v2.00
[ 7.224850] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.227024] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.251695] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.277018] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.295141] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 7.295660] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 7.303373] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 7.303783] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.306049] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 7.306086] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.306110] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.306128] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.306145] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.306357] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.313641] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 7.313694] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 7.322989] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 7.323040] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 7.328322] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 7.328375] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 7.511570] pisound: Searching for spi device…
[ 7.511627] pisound: Found!
[ 7.633421] pisound: Reading card info failed: -22
[ 7.633471] pisound: pisnd_spi_init failed: -22
[ 7.633525] snd-rpi-pisound: probe of soc:sound failed with error -22
[ 7.770331] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.917370] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 8.021587] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 8.032077] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 8.032387] usbcore: registered new interface driver brcmfmac
[ 8.057774] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.raspberrypi,3-model-b.txt failed with error -2
[ 8.261321] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 8.261438] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[ 8.262313] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
[ 10.490800] random: crng init done
[ 10.490830] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.556708] uart-pl011 3f201000.serial: no DMA platform data
[ 11.001184] 8021q: 802.1Q VLAN Support v1.8
[ 11.286662] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 11.351637] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 11.948071] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 13.035852] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 14.354567] ICMPv6: process `dhcpcd’ is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 14.924788] Bluetooth: Core ver 2.22
[ 14.924852] NET: Registered protocol family 31
[ 14.924859] Bluetooth: HCI device and connection manager initialized
[ 14.924877] Bluetooth: HCI socket layer initialized
[ 14.924887] Bluetooth: L2CAP socket layer initialized
[ 14.924903] Bluetooth: SCO socket layer initialized
[ 14.937936] Bluetooth: HCI UART driver ver 2.3
[ 14.937951] Bluetooth: HCI UART protocol H4 registered
[ 14.938055] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 14.939799] Bluetooth: HCI UART protocol Broadcom registered
[ 15.267228] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 15.267241] Bluetooth: BNEP filters: protocol multicast
[ 15.267268] Bluetooth: BNEP socket layer initialized
[ 15.431667] Bluetooth: RFCOMM TTY layer initialized
[ 15.431692] Bluetooth: RFCOMM socket layer initialized
[ 15.431734] Bluetooth: RFCOMM ver 1.11
[ 40.647137] pisound: Searching for spi device…
[ 40.647151] pisound: Found!
[ 40.712465] pisound: Reading card info failed: -22
[ 40.712490] pisound: pisnd_spi_init failed: -22
[ 40.712519] snd-rpi-pisound: probe of soc:sound failed with error -22
[ 117.977189] pisound: Searching for spi device…
[ 117.977202] pisound: Found!
[ 118.042510] pisound: Reading card info failed: -22
[ 118.042533] pisound: pisnd_spi_init failed: -22
[ 118.042558] snd-rpi-pisound: probe of soc:sound failed with error -22
[ 225.598019] pisound: Searching for spi device…
[ 225.598031] pisound: Found!
[ 225.663452] pisound: Reading card info failed: -22
[ 225.663522] pisound: pisnd_spi_init failed: -22
[ 225.663594] snd-rpi-pisound: probe of soc:sound failed with error -22
I really hope there is a way to resolve this. Meanwhile, I’ll have to make do with the superb Midihub (:
