MODEP- how to access via browser on RPI
Hello, I am trying to access the UI for Modep, I have the pi connected by ethernet and tried to enter the address given here: http://127.0.0.1/ - Only if on Raspberry Pi itself. but it is unable to connect. (I tried the other addresses and none worked for me); I do have access to an iphone, downloaded Termius and got that to start so it mirrored the Patchbox set up info; but I did not understand how I was to move from there to the MODEP browser.
I am stumped, if anyone can suggest what to do I’d be very greatful, kind regards
If it doesn’t connect, check whether the necessary services are running:
Thankyou, I followed this and got it working. On my headphones the audio is mono-patched to left and right, can you suggest what I should check for that, please?
I think I must be doing something wrong in any case, as the whole process of loading pedals and hooking them up is very slow. I presume this must be a tech issue but beyond your and the guidance I have no idea how to make that speedier.
The audio sounds grainy (would you think that the Soundpi will actually give me a better experience?)
kind regards
Do you mean a Pisound? :smiley: The sound is good with it.
The effects are to be downloaded through the integrated Patchstorage browser. It shouldn’t be taking very long.
Thanks, yeah Pisound is what I meant :slight_smile:
…in the interim is there something that I can check to see why the Scarlett 8i6 headphone was just giving mono?
I’ll try accessing the Mod site using a second laptop on same network if I can, and maybe that will be speedier to try than the Pi itself?
kind regards
