Channel filter bug (Sysex related?)
I can’t believe Midihub had a six seven bug from way before it was cool. :smiley: Pretty much since the initial release.
We have just uploaded 1.16.7 firmware which fixes this issue:
Before we publish it through the integrated Editor update channel on Monday, you may do the offline upgrade (download the .bfw and do Device → Flash Firmware…)
There’s also a one half fix for SysEx event display in the MIDI Monitor pane. The other half is going to be released with the next Editor update. It’s only a display issue, the data itself is all fine at the MIDI level itself.
