Using the Patchbox os and rasp5 for sound module
I wanted to use my patchbox to alternate between midi usb in synth guitar with a fishman triple play and also guitar with modep pedal boards switched by midi. Can anyone recommend what the best sound module would be to run on the pi? I would love to have motif level sounds or sampled instruments instead of sound fonts.. How would I achieve switching between synth and guitar modes with a pisound?
So you want to use either USB MIDI signals for use with sound generators, as well as the analog audio input for the guitar?
If I understand this right, it should be enough to build out your pedalboard accordingly in MODEP - it can both process the guitar sound, and produce synth sounds via MIDI. If you need to switch one on and off, you could put in some utility pedals in there, to cut the signal at the right parts, mapped to MIDI controls.
