Hi folks,
I have a need for a high quality stereo pitch shifter to shift live recorded analog audio loops (e.g. bass + piano backing tracks) by up to one octave in semitone steps without changing tempo. The pitch shift amount shall be settable on the fly via MIDI command (e.g. cc message) between 0 and 11 semitones.
I have not been able to find something that does this on the market.
Then I remembered that I have a Pisound unit which I think should be able to do the job.
So I thought about using Patchbox OS and MODEP and the CAPO plugin to do the pitch shift.
Since I’m new to this I would appriciate if you guys can answer some questions.
Is this a good approach? Do you think that this can work or would you suggest a different approach?
How can I implement MIDI control for the MOD CAPO plugin?
Thank you very much for your comments and help
Pirmin
