Would it be possible to use the pisound with a raspberry pi 5 to control drumgizmo with MIDI. Would it be possible to use this as a drum module or would there be to much latancy?
Giedrius
2
It should work just fine, assuming you’ll know how to set it up properly, it looks like it needs to be built from source and used from an LV2 host program.
Related topics
| Topic | Replies | Views | Activity | |
| Is Pisound right for me? Here’s my use case … | 6 | 416 | September 20, 2024 | |
Possible to use PiSound as sample bank?
3 | 1154 | February 11, 2019 | |
| Pisound for Raspberry Pi 5? | 85 | 6309 | June 23, 2024 | |
| Compatability with Rasberry Pi 5 | 2 | 526 | November 3, 2023 | |
| Creating a drum machine that can play samples and generate drum sounds | 1 | 99 | March 4, 2025 | |
| Edrumin PiSound Apps | 3 | 551 | October 31, 2022 | |
| Pisound as effect box and MIDI router | 3 | 213 | March 8, 2024 | |
| Midi to usb on the pisound possible? | 4 | 577 | April 13, 2022 | |
| Pisound as PC audio interface? | 2 | 604 | January 23, 2022 | |
Working on a MIDI Concertina
4 | 1042 | March 13, 2019 |
