Simple question - change cc# to another cc#
I haven’t used the midihub in quite some time. My recollection was that it was easy to use, but that the docs were hard to work from.
I’m to give up since i’ve spent way too much time on this simplest of functions. I remember that doing this kind of thing is easy.
All i’m trying to do is change incoming cc#7 to another cc#. The remapper just seems to be for remapping ranges. Is this done through the transform? That seems needlessly complicated for such an easy function.
EDIT - found the answer in an old post here. I misunderstood the help for the cc remapper.
Good to hear you’ve managed to solve it :slight_smile: We accept suggestions for how to make the documentation better. :wink:
