I’m trying to figure out how to get bypass for a pipeline to toggle off/on using an external controller.
I have:
Morningstar MC6 PRO
Blokas Minihub
Korg Opsix (MIDI ch 1)
Korg Minilogue XD (MIDI ch 2)
Physically I have them wired this way*
MC6.Midi Out -> MidiHub.Midi In A
Opsix.Midi Out -> MidiHub.Midi In B
MidiHub.Midi Out A -> Opsix.Midi In
MidiHub.Midi Out B -> MLXD.Midi In
I set up a pipeline to remap channel messages coming over MidiHub.Midi In B (basically I’m trying to use the Opsix as a controller for the Minilogue without changing channels). The pipeline works by itself. It correctly maps notes to MIDI channel 2 and when I click bypass in the Minihub editor, the notes stop getting mapped to midi channel 2.
My problem is trying to set up a bypass toggle using the morningstar editor.
I have
FROM B
-> CH FILTER (allow ch 1 only)
-> CH REMAP (
In Low 1,
In High 16,
Out Low 2,
Out High 2)
-> TO B
And then FROM B i created a mapping by having the Midihub listen as I pressed the button sending the message I want to send to the Midihub to trigger the bypass.
It recorded this, and this is what I see when I monitor messages on MidiHub’s Input A:
Ch. 16 CC 20 127
In the mapping dialog for the bypass for the FROM B start of the above pipeline, I have
Port: MIDI A Mode: Toggle
Type:CC Low: 0
Channel: 16 High: 127
Id: 20 Drop: [ ] (unchecked)
When I press the button on the MC6, the bypass get checked. When I press it again it does not get unchecked.
I have other pipelines set up on this (basically all messages from MIDI IN A go to MIDI OUT A and B so I can use the MC6 to send messages to the Opsix and Minilogue) those pipelines are working fine. I don’t have any bypass toggling set up on those.
It seems like there must be some small detail I’m missing, but I’m not sure what.
