I’m a beginner with pisound and I have been following the setup documentation. However, I’m stuck here trying to get MODEP to work. I can’t get the UI to show up at http://172.24.1.1 and found that the mod-ui service is failing.
I checked jack, modep-mod-host and they seem to be working fine. (using the instructions on Troubleshooting page). I ran sudo journalctl --unit modep-mod-ui and I found the following error in the journal.
modep-mod-ui.service: Changing to the requested working directory failed: No such file or directory
modep-mod-ui.service: Failed at step CHDIR spwaning /usr/bin/authbind: No such file or directory
Any suggestions on how to solve this? Thanks.
