Raspbian/RPI4 - MODEP not starting
I installed pisound on a raspbian instance (RPI4)
after having installed modep, there is no UI available even localy
this used to work (2021? 2022?), I had to reinstall everything since there was no way to disable wifi hotspot from the menu
thanks for your help on this
installation:
curl https://blokas.io/pisound/install.sh | sh
sudo apt install modep
sudo systemctl stop modep-mod-host modep-mod-ui
sudo systemctl start modep-mod-host modep-mod-ui
sudo systemctl status modep-mod-host modep-mod-ui
error:
lines 1-22/22 (END)
○ modep-mod-host.service - MOD-host
     Loaded: loaded (/lib/systemd/system/modep-mod-host.service; disabled; preset: enabled)
     Active: inactive (dead) (Result: exit-code) since Thu 2024-05-02 19:59:58 CEST; 1min 58s ago
   Duration: 41ms
    Process: 2522 ExecStart=/usr/bin/mod-host -p 5555 -f 5556 (code=exited, status=0/SUCCESS)
   Main PID: 2523 (code=exited, status=1/FAILURE)
        CPU: 38ms
May 02 19:59:58 pisound systemd[1]: Stopped modep-mod-host.service - MOD-host.
○ modep-mod-ui.service - MOD-UI
     Loaded: loaded (/lib/systemd/system/modep-mod-ui.service; enabled; preset: enabled)
     Active: inactive (dead) since Thu 2024-05-02 19:59:58 CEST; 1min 58s ago
   Duration: 386ms
    Process: 2526 ExecStart=/usr/bin/authbind /usr/bin/mod-ui (code=killed, signal=TERM)
   Main PID: 2526 (code=killed, signal=TERM)
        CPU: 351ms
May 02 19:59:57 pisound systemd[1]: Started modep-mod-ui.service - MOD-UI.
May 02 19:59:58 pisound systemd[1]: Stopping modep-mod-ui.service - MOD-UI...
May 02 19:59:58 pisound systemd[1]: modep-mod-ui.service: Deactivated successfully.
May 02 19:59:58 pisound systemd[1]: Stopped modep-mod-ui.service - MOD-UI.
/boot/firmware/config.txt
# For more options and information see
# http://rptl.io/configtxt
# Some settings may impact device functionality. See link above for details
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Additional overlays and parameters are documented
# /boot/firmware/overlays/README
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Automatically load initramfs files, if found
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Don't have the firmware create an initial video= setting in cmdline.txt.
# Use the kernel's default instead.
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
# Disable compensation for displays with overscan
disable_overscan=1
# Run as fast as firmware / board allows
arm_boost=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
ok my bad, I simply forgot to reattach the pisound hat ( how retarded is that :slight_smile: )
another thing to mention is that the service also needs to be enabled to start on boot
