Midi Hub issues with Transform function
I’m trying to using the Blokas MIDI Hub to transform MIDI note messages from the NMSVE midi controller into program changes for the Voicelive 3.
This seems to work fine with my Kronos keyboard, but I’m having trouble getting it to work properly with the NMSVE.
The issue is that the note I’ve set to trigger the Program Change (C-2) doesn’t respond correctly. Instead, every note above D-2 ends up triggering the Program Change, which is really strange.
Has anyone run into anything like this before?
Current signal chain
NMSVE midi controller → WIDI Jack (via bluetooth) → Blokas MIDIHub (MIDI C IN) → VoiceLive 3 (MIDI B OUT)
(I’m also sending MIDI messages to the VoiceLive 3 from the Kronos via MIDI B IN)
Thanks again for your help!
It looks like you have MIDI mapped the ‘What’ parameter, you probably didn’t intend to do that. Try unmapping the parameter by expanding the little triangle on the left (>) and removing the mapping by clicking the ‘U’ button (short for Unmap).
