Jackd won't start
Hello everybody!
I just recieved my pisound and i’m really happy, but I can’t start jackd via qjackctl.
I’m running the pi with the ubuntu mate image.
the system ist correctly set up with pisound as main sound card. If I put the default soundcard back, jacks starts correctly.
what i’m doing wrong?
here is the error message of jack:
Summary
18:42:14.894 Statistics reset.
18:42:14.970 ALSA connection change.
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
18:42:25.275 JACK is starting…
18:42:25.277 /usr/bin/jackd -v -r -dalsa -dhw:pisound -r44100 -p1024 -n3 -Xseq
18:42:25.436 JACK was started with PID=2983.
jackdmp 1.9.11
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2014 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in non-realtime mode
self-connect-mode is “Don’t restrict self connect requests”
Cannot lock down 82278944 byte memory area (Cannot allocate memory)
Jack: JackPosixThread::StartImp : create non RT thread
Jack: JackPosixThread::ThreadHandler : start
Jack: playback device hw:pisound
Jack: capture device hw:pisound
Jack: apparent rate = 44100
Jack: frames per period = 1024
Jack: JackDriver::Open capture_driver_name = hw:pisound
Jack: JackDriver::Open playback_driver_name = hw:pisound
Jack: Check protocol client = 8 server = 8
Jack: JackEngine::ClientInternalOpen: name = system
Jack: JackEngine::AllocateRefNum ref = 0
Jack: JackPosixSemaphore::Allocate name = jack_sem.1000_default_system val = 0
Jack: JackEngine::NotifyAddClient: name = system
Jack: JackGraphManager::SetBufferSize size = 1024
Jack: JackConnectionManager::DirectConnect first: ref1 = 0 ref2 = 0
Jack: JackGraphManager::ConnectRefNum cur_index = 0 ref1 = 0 ref2 = 0
Jack: JackDriver::SetupDriverSync driver sem in flush mode
audio_reservation_init
Acquire audio card Audio1
creating alsa driver … hw:pisound|hw:pisound|1024|3|44100|0|0|nomon|swmeter|-|32bit
configuring for 44100Hz, period = 1024 frames (23.2 ms), buffer = 3 periods
ALSA: mmap-based access is not possible for the capture stream of this audio interface
ALSA: cannot configure capture channel
Jack: JackDriver::Close
Jack: JackConnectionManager::DirectDisconnect last: ref1 = 0 ref2 = 0
Jack: JackGraphManager::DisconnectRefNum cur_index = 0 ref1 = 0 ref2 = 0
Jack: JackEngine::ClientInternalClose ref = 0
Jack: JackEngine::ClientCloseAux ref = 0
Jack: JackGraphManager::RemoveAllPorts ref = 0
Jack: JackPosixSemaphore::Destroy name = jack_sem.1000_default_system
Jack: ~JackDriver
Cannot initialize driver
Jack: no message buffer overruns
Jack: JackPosixThread::ThreadHandler : exit
Jack: JackPosixThread::Stop
JackServer::Open failed with -1
Jack: Succeeded in unlocking 82278944 byte memory area
Jack: JackShmMem::delete size = 0 index = 0
Jack: ~JackDriver
Jack: Succeeded in unlocking 1232 byte memory area
Jack: JackShmMem::delete size = 0 index = 1
Jack: Cleaning up shared memory
Jack: Cleaning up files
Jack: Unregistering server `default’
Failed to open server
18:42:25.746 JACK was stopped
18:42:27.454 Could not connect to JACK server as client. - Overall operation failed. - Unable to connect to server. Please check the messages window for more info.
any clue? thanks in advance!!
all the best
vince
Hi, try using 48000 (or one of 96000, 192000) sampling rate instead of 44100.
it works now, thanks!
(but I changed to raspbian)
