I have use the standard systemctl start jack to start the jack server with the line you specifiied.
I execute the jack_connect commands as given and get no sound at the amplifier (attached to 1.4" out port)
syslog shows:
Nov 29 20:24:42 cuimhne-bbb8f520 systemd[1]: Started JACK Server.
Nov 29 20:24:42 cuimhne-bbb8f520 jackdrc[10780]: Home directory not accessible: Permission denied
Nov 29 20:24:42 cuimhne-bbb8f520 jackdrc[10780]: jackdmp 1.9.12
Nov 29 20:24:42 cuimhne-bbb8f520 jackdrc[10780]: Copyright 2001-2005 Paul Davis and others.
Nov 29 20:24:42 cuimhne-bbb8f520 jackdrc[10780]: Copyright 2004-2016 Grame.
Nov 29 20:24:42 cuimhne-bbb8f520 jackdrc[10780]: Copyright 2016-2017 Filipe Coelho.
Nov 29 20:24:42 cuimhne-bbb8f520 jackdrc[10780]: jackdmp comes with ABSOLUTELY NO WARRANTY
Nov 29 20:24:42 cuimhne-bbb8f520 jackdrc[10780]: This is free software, and you are welcome to redistribute it
Nov 29 20:24:42 cuimhne-bbb8f520 jackdrc[10780]: under certain conditions; see the file COPYING for details
Nov 29 20:24:42 cuimhne-bbb8f520 jackdrc[10780]: JACK server starting in realtime mode with priority 95
Nov 29 20:24:42 cuimhne-bbb8f520 jackdrc[10780]: self-connect-mode is "Don't restrict self connect requests"
Nov 29 20:24:43 cuimhne-bbb8f520 jackdrc[10780]: creating alsa driver ... hw:pisound|hw:pisound|128|2|48000|0|0|nomon|swmeter|soft-mode|16bit
Nov 29 20:24:43 cuimhne-bbb8f520 jackdrc[10780]: configuring for 48000Hz, period = 128 frames (2.7 ms), buffer = 2 periods
Nov 29 20:24:43 cuimhne-bbb8f520 jackdrc[10780]: ALSA: final selected sample format for capture: 16bit little-endian
Nov 29 20:24:43 cuimhne-bbb8f520 jackdrc[10780]: ALSA: use 2 periods for capture
Nov 29 20:24:43 cuimhne-bbb8f520 jackdrc[10780]: ALSA: final selected sample format for playback: 16bit little-endian
Nov 29 20:24:43 cuimhne-bbb8f520 jackdrc[10780]: ALSA: use 2 periods for playback
Nov 29 20:24:43 cuimhne-bbb8f520 jackdrc[10780]: port created: Midi-Through:midi/playback_1
Nov 29 20:24:43 cuimhne-bbb8f520 jackdrc[10780]: port created: Midi-Through:midi/capture_1
Nov 29 20:24:43 cuimhne-bbb8f520 jackdrc[10780]: port created: pisound:midi/playback_1
Nov 29 20:24:43 cuimhne-bbb8f520 jackdrc[10780]: port created: pisound:midi/capture_1
I assume the home directory is not an issue, it does exist and is world writable (that may be the problem)
jack_lsp -c shows:
cuimhne@cuimhne-bbb8f520:/tmp $ jack_lsp -c
system:capture_1
system:playback_1
system:capture_2
system:playback_2
system:playback_1
system:capture_1
system:playback_2
system:capture_2
system:midi_capture_1
system:midi_playback_1
system:midi_capture_2
system:midi_playback_2
running meterbridge -t vu system:capture_1 system:playback_1 & shows that the capture and playback both have signal.
running jack_capture --chnnels 2 produces a very nice recording (no pops, clicks, or distortion)
os-release data:
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
with pisound-btn, pisound-ctl, osc2midi, amidiauto, pulseaudio-module-jack, jack2d, blokas-jack installed.
Any idea what the issue might be?
Any help would be appreciated,
Claude
