Hi all,
I’m trying to run qjackctl on a fresh Patchbox OS install; I installed it by using
sudo apt-get install qjackctl
When I run it and try to start the server, I get the error messages that I’ve copied below. Should I alter the existing jack installation in some way?
Thanks in advance.
01:01:26.555 Statistics reset.
01:01:26.620 ALSA connection change.
Cannot read socket fd = 14 err = Success
CheckRes error
JackSocketClientChannel read fail
Cannot open qjackctl client
JackShmReadWritePtr1::~JackShmReadWritePtr1 - Init not done for -1, skipping unlock
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
01:01:31.709 ALSA connection graph change.
01:01:39.670 JACK is starting...
01:01:39.672 /usr/bin/jackd -dalsa -dhw:0 -r48000 -p1024 -n2
CheckRes error
01:01:39.735 JACK was started with PID=2001.
jackdmp 1.9.12
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2016 Grame.
Copyright 2016-2017 Filipe Coelho.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
self-connect-mode is "Don't restrict self connect requests"
Cannot allocate synchro
Cannot allocate internal client for driver
Cannot initialize driver
JackServer::Open failed with -1
Failed to open server
01:01:40.522 JACK was stopped
01:01:46.978 Could not connect to JACK server as client. - Overall operation failed. - Server communication error. Please check the messages window for more info.
CheckRes error
