Stopped recognizing the Pisound
Hello,
I upgraded the Patchbox OS yesterday. Since then it has stopped recognizing the Pisound. I have two Pisounds and the system behaves the same on both. The Patchbox OS upgrade was performed on a Raspberry PI 5 with 4GB RAM.
patch@***:~ $ amidi -l
Dir Device    Name
patch@***:~ $ arecord -l
**** Liste der Hardware-Geräte (CAPTURE) ****
patch@***:~ $ aplay -l
**** Liste der Hardware-Geräte (PLAYBACK) ****
Karte 0: vc4hdmi0 [vc4-hdmi-0], Gerät 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
  Sub-Geräte: 1/1
  Sub-Gerät #0: subdevice #0
Karte 1: vc4hdmi1 [vc4-hdmi-1], Gerät 0: MAI PCM i2s-hifi-0 [MAI PCM i2s-hifi-0]
  Sub-Geräte: 1/1
patch@***:~ $ sudo journalctl -u jack.service
...skipping...
Apr 30 10:28:38 patchbox-001 jackdrc[979]: jackdmp 1.9.21
Apr 30 10:28:38 patchbox-001 jackdrc[979]: Copyright 2001-2005 Paul Davis and others.
Apr 30 10:28:38 patchbox-001 jackdrc[979]: Copyright 2004-2016 Grame.
Apr 30 10:28:38 patchbox-001 jackdrc[979]: Copyright 2016-2022 Filipe Coelho.
Apr 30 10:28:38 patchbox-001 jackdrc[979]: jackdmp comes with ABSOLUTELY NO WARRANTY
Apr 30 10:28:38 patchbox-001 jackdrc[979]: This is free software, and you are welcome to redistribute it
Apr 30 10:28:38 patchbox-001 jackdrc[979]: under certain conditions; see the file COPYING for details
Apr 30 10:28:38 patchbox-001 jackdrc[979]: JACK server starting in realtime mode with priority 95
Apr 30 10:28:38 patchbox-001 jackdrc[979]: self-connect-mode is "Don't restrict self connect requests"
Apr 30 10:28:38 patchbox-001 jackdrc[979]: creating alsa driver ... hw:vc4hdmi0|hw:vc4hdmi0|256|2|44100|0|0|nomon|swmet>
Apr 30 10:28:38 patchbox-001 jackdrc[979]: ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture->
Apr 30 10:28:38 patchbox-001 jackdrc[979]: Cannot initialize driver
Apr 30 10:28:38 patchbox-001 jackdrc[979]: JackServer::Open failed with -1
Apr 30 10:28:38 patchbox-001 jackdrc[979]: Failed to open server
Apr 30 10:28:38 patchbox-001 systemd[1]: jack.service: Main process exited, code=exited, status=255/EXCEPTION
Apr 30 10:28:38 patchbox-001 systemd[1]: jack.service: Failed with result 'exit-code'.
Apr 30 10:28:39 patchbox-001 systemd[1]: jack.service: Scheduled restart job, restart counter is at 4.
Apr 30 10:28:39 patchbox-001 systemd[1]: Stopped jack.service - JACK Server.
Apr 30 10:28:39 patchbox-001 systemd[1]: Started jack.service - JACK Server.
Apr 30 10:28:39 patchbox-001 jackdrc[999]: Failed to create secure directory (/nonexistent/.config/pulse): No such file>
Apr 30 10:28:39 patchbox-001 jackdrc[999]: jackdmp 1.9.21
Apr 30 10:28:39 patchbox-001 jackdrc[999]: Copyright 2001-2005 Paul Davis and others.
Apr 30 10:28:39 patchbox-001 jackdrc[999]: Copyright 2004-2016 Grame.
Apr 30 10:28:39 patchbox-001 jackdrc[999]: Copyright 2016-2022 Filipe Coelho.
Apr 30 10:28:39 patchbox-001 jackdrc[999]: jackdmp comes with ABSOLUTELY NO WARRANTY
Apr 30 10:28:39 patchbox-001 jackdrc[999]: This is free software, and you are welcome to redistribute it
Apr 30 10:28:39 patchbox-001 jackdrc[999]: under certain conditions; see the file COPYING for details
Apr 30 10:28:39 patchbox-001 jackdrc[999]: JACK server starting in realtime mode with priority 95
Apr 30 10:28:39 patchbox-001 jackdrc[999]: self-connect-mode is "Don't restrict self connect requests"
Apr 30 10:28:39 patchbox-001 jackdrc[999]: creating alsa driver ... hw:vc4hdmi0|hw:vc4hdmi0|256|2|44100|0|0|nomon|swmet>
Apr 30 10:28:39 patchbox-001 jackdrc[999]: ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture->
Apr 30 10:28:39 patchbox-001 jackdrc[999]: Cannot initialize driver
Apr 30 10:28:39 patchbox-001 jackdrc[999]: JackServer::Open failed with -1
Apr 30 10:28:39 patchbox-001 jackdrc[999]: Failed to open server
Apr 30 10:28:39 patchbox-001 systemd[1]: jack.service: Main process exited, code=exited, status=255/EXCEPTION
Apr 30 10:28:39 patchbox-001 systemd[1]: jack.service: Failed with result 'exit-code'.
Apr 30 10:28:41 patchbox-001 systemd[1]: jack.service: Scheduled restart job, restart counter is at 5.
Apr 30 10:28:41 patchbox-001 systemd[1]: Stopped jack.service - JACK Server.
Apr 30 10:28:41 patchbox-001 systemd[1]: jack.service: Start request repeated too quickly.
Apr 30 10:28:41 patchbox-001 systemd[1]: jack.service: Failed with result 'exit-code'.
Apr 30 10:28:41 patchbox-001 systemd[1]: Failed to start jack.service - JACK Server.
Apr 30 10:41:41 patchbox-001 systemd[1]: Started jack.service - JACK Server.
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: Failed to create secure directory (/nonexistent/.config/pulse): No such fil>
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: jackdmp 1.9.21
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: Copyright 2001-2005 Paul Davis and others.
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: Copyright 2004-2016 Grame.
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: Copyright 2016-2022 Filipe Coelho.
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: jackdmp comes with ABSOLUTELY NO WARRANTY
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: This is free software, and you are welcome to redistribute it
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: under certain conditions; see the file COPYING for details
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: JACK server starting in realtime mode with priority 95
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: self-connect-mode is "Don't restrict self connect requests"
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: creating alsa driver ... hw:vc4hdmi0|hw:vc4hdmi0|256|2|44100|0|0|nomon|swme>
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: ALSA: Cannot open PCM device alsa_pcm for playback. Falling back to capture>
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: Cannot initialize driver
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: JackServer::Open failed with -1
Apr 30 10:41:41 patchbox-001 jackdrc[1324]: Failed to open server
Apr 30 10:41:41 patchbox-001 systemd[1]: jack.service: Main process exited, code=exited, status=255/EXCEPTION
Apr 30 10:41:41 patchbox-001 systemd[1]: jack.service: Failed with result 'exit-code'.
Apr 30 10:41:42 patchbox-001 systemd[1]: jack.service: Scheduled restart job, restart counter is at 1.
Apr 30 10:41:42 patchbox-001 systemd[1]: Stopped jack.service - JACK Server.
Apr 30 10:41:42 patchbox-001 systemd[1]: jack.service: Start request repeated too quickly.
Apr 30 10:41:42 patchbox-001 systemd[1]: jack.service: Failed with result 'exit-code'.
Apr 30 10:41:42 patchbox-001 systemd[1]: Failed to start jack.service - JACK Server.
Can someone help me with this?
Beste Regards
Maciej
Here is the config.txt:
# For more options and information see
# http://rptl.io/configtxt
# Some settings may impact device functionality. See link above for details
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Additional overlays and parameters are documented
# /boot/firmware/overlays/README
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Automatically load initramfs files, if found
auto_initramfs=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Don't have the firmware create an initial video= setting in cmdline.txt.
# Use the kernel's default instead.
disable_fw_kms_setup=1
# Run in 64-bit mode
arm_64bit=1
# Disable compensation for displays with overscan
disable_overscan=1
# Run as fast as firmware / board allows
arm_boost=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[all]
Please post the output of dmesg.
Btw, use ``` at the start of the quoted output, and at the end, this is easier to read. :slight_smile:
Here is it:
Part 1:
patch@***:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x414fd0b1]
[    0.000000] Linux version 6.12.20+rpt-rpi-2712 (serge@raspberrypi.com) (aarch64-linux-gnu-gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.12.20-1+rpt1~bpo12+1 (2025-03-19)
[    0.000000] KASLR enabled
[    0.000000] random: crng init done
[    0.000000] Machine model: Raspberry Pi 5 Model B Rev 1.0
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000018000000, size 320 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000018000000..0x000000002bffffff (327680 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x0000000000000000..0x000000000007ffff (512 KiB) nomap non-reusable atf@0
[    0.000000] OF: reserved mem: 0x000000003fd165a0..0x000000003fd165d6 (0 KiB) nomap non-reusable nvram@0
[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000] NODE_DATA(0) allocated [mem 0xffd98b80-0xffd9b97f]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000000007ffff]
[    0.000000]   node   0: [mem 0x0000000000080000-0x000000003fbfffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000] On node 0, zone DMA: 256 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 15 pages/cpu s193368 r8192 d44200 u245760
[    0.000000] pcpu-alloc: s193368 r8192 d44200 u245760 alloc=15*16384
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: SSBS not fully self-synchronizing
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:C9:CA:01 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=39633f77-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
[    0.000000] Dentry cache hash table entries: 524288 (order: 8, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 7, 2097152 bytes, linear)
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 261888
[    0.000000] Policy zone: DMA
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 45035 entries in 44 pages
[    0.000000] ftrace: allocated 44 pages with 3 groups
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000123] Console: colour dummy device 80x25
[    0.000129] printk: legacy console [tty1] enabled
[    0.000266] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[    0.000273] pid_max: default: 32768 minimum: 301
[    0.000295] LSM: initializing lsm=capability
[    0.000372] Mount-cache hash table entries: 8192 (order: 2, 65536 bytes, linear)
[    0.000388] Mountpoint-cache hash table entries: 8192 (order: 2, 65536 bytes, linear)
[    0.020007] rcu: Hierarchical SRCU implementation.
[    0.020015] rcu:     Max phase no-delay instances is 1000.
[    0.020064] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.020391] EFI services will not be available.
[    0.020443] smp: Bringing up secondary CPUs ...
[    0.024099] Detected PIPT I-cache on CPU1
[    0.024135] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
[    0.028129] Detected PIPT I-cache on CPU2
[    0.028165] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
[    0.032105] Detected PIPT I-cache on CPU3
[    0.032126] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
[    0.032153] smp: Brought up 1 node, 4 CPUs
[    0.032169] SMP: Total of 4 processors activated.
[    0.032171] CPU: All CPU(s) started at EL2
[    0.032174] CPU features: detected: 32-bit EL0 Support
[    0.032178] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.032181] CPU features: detected: Common not Private translations
[    0.032184] CPU features: detected: CRC32 instructions
[    0.032187] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.032190] CPU features: detected: LSE atomic instructions
[    0.032192] CPU features: detected: Privileged Access Never
[    0.032194] CPU features: detected: RAS Extension Support
[    0.032196] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.032223] alternatives: applying system-wide alternatives
[    0.033838] CPU features: detected: Hardware dirty bit management on CPU0-3
[    0.034000] Memory: 3784800K/4190208K available (14016K kernel code, 2264K rwdata, 4800K rodata, 5440K init, 647K bss, 70880K reserved, 327680K cma-reserved)
[    0.034145] devtmpfs: initialized
[    0.036204] Enabled cp15_barrier support
[    0.036212] Enabled setend support
[    0.036266] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.036273] futex hash table entries: 1024 (order: 2, 65536 bytes, linear)
[    0.036881] 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[    0.036887] 0 pages in range for non-PLT usage
[    0.036888] 129352 pages in range for PLT usage
[    0.036951] pinctrl core: initialized pinctrl subsystem
[    0.037079] DMI not present or invalid.
[    0.037729] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.038087] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.038142] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.038200] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.038218] audit: initializing netlink subsys (disabled)
[    0.038264] audit: type=2000 audit(0.000:1): state=initialized audit_enabled=0 res=1
[    0.038358] thermal_sys: Registered thermal governor 'step_wise'
[    0.038367] cpuidle: using governor menu
[    0.038413] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.038435] ASID allocator initialised with 32768 entries
[    0.038657] Serial: AMBA PL011 UART driver
[    0.039423] bcm2835-mbox 107c013880.mailbox: mailbox enabled
[    0.039669] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 15, base_baud = 0) is a PL011 rev2
[    0.039681] printk: legacy console [ttyAMA10] enabled
[    0.804024] raspberrypi-firmware soc:firmware: Attached to firmware from 2025-01-22T00:16:51, variant start_cd
[    0.818076] raspberrypi-firmware soc:firmware: Firmware hash is a775306300000000000000000000000000000000
[    0.832617] /axi/interrupt-controller@7fff9000: Fixed dependency cycle(s) with /axi/interrupt-controller@7fff9000
[    0.851231] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
[    0.858569] iommu: Default domain type: Translated
[    0.863592] iommu: DMA domain TLB invalidation policy: strict mode
[    0.876298] SCSI subsystem initialized
[    0.880090] usbcore: registered new interface driver usbfs
[    0.885600] usbcore: registered new interface driver hub
[    0.890938] usbcore: registered new device driver usb
[    0.896083] pps_core: LinuxPPS API ver. 1 registered
[    0.901068] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.910239] PTP clock support registered
[    0.914424] vgaarb: loaded
[    0.917220] clocksource: Switched to clocksource arch_sys_counter
[    1.049456] VFS: Disk quotas dquot_6.6.0
[    1.053404] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
[    1.061683] NET: Registered PF_INET protocol family
[    1.066696] IP idents hash table entries: 65536 (order: 5, 524288 bytes, linear)
[    1.075325] tcp_listen_portaddr_hash hash table entries: 2048 (order: 1, 32768 bytes, linear)
[    1.083934] Table-perturb hash table entries: 65536 (order: 4, 262144 bytes, linear)
[    1.091713] TCP established hash table entries: 32768 (order: 4, 262144 bytes, linear)
[    1.099744] TCP bind hash table entries: 32768 (order: 6, 1048576 bytes, linear)
[    1.107930] TCP: Hash tables configured (established 32768 bind 32768)
[    1.114613] MPTCP token hash table entries: 4096 (order: 2, 98304 bytes, linear)
[    1.122108] UDP hash table entries: 2048 (order: 2, 65536 bytes, linear)
[    1.128867] UDP-Lite hash table entries: 2048 (order: 2, 65536 bytes, linear)
[    1.136116] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.141946] RPC: Registered named UNIX socket transport module.
[    1.147889] RPC: Registered udp transport module.
[    1.152606] RPC: Registered tcp transport module.
[    1.157324] RPC: Registered tcp-with-tls transport module.
[    1.162826] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.169299] PCI: CLS 0 bytes, default 64
[    1.174893] kvm [1]: nv: 554 coarse grained trap handlers
[    1.180416] Trying to unpack rootfs image as initramfs...
[    1.180491] kvm [1]: IPA Size Limit: 40 bits
[    1.190150] kvm [1]: GICV region size/alignment is unsafe, using trapping (reduced performance)
[    1.199081] kvm [1]: vgic interrupt IRQ9
[    1.203064] kvm [1]: VHE mode initialized successfully
[    1.208957] Initialise system trusted keyrings
[    1.213614] workingset: timestamp_bits=42 max_order=18 bucket_order=0
[    1.220387] NFS: Registering the id_resolver key type
[    1.225488] Key type id_resolver registered
[    1.229685] Key type id_legacy registered
[    1.233714] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.240443] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.248205] Key type asymmetric registered
[    1.252339] Asymmetric key parser 'x509' registered
[    1.257315] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.264839] io scheduler mq-deadline registered
[    1.269391] io scheduler kyber registered
[    1.273431] io scheduler bfq registered
[    1.281663] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7c502000, parent irq: 26)
[    1.290912] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d503000, parent irq: 27)
[    1.298709] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508380, parent irq: 28)
[    1.306470] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508400, parent irq: 29)
[    1.314241] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7d510600, parent irq: 30)
[    1.323390] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d517b00, parent irq: 31)
[    1.333083] ledtrig-cpu: registered to indicate activity on CPUs
[    1.366146] Freeing initrd memory: 16768K
[    1.400934] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[    1.407553] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 33, base_baud = 6000000) is a Broadcom BCM7271 UART
[    1.418168] serial serial0: tty port ttyS0 registered
[    1.423495] iproc-rng200 107d208000.rng: hwrng registered
[    1.428950] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
[    1.437431] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
[    1.445801] brd: module loaded
[    1.449836] loop: module loaded
[    1.453085] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.460448] Loading iSCSI transport class v2.0-870.
[    1.466008] usbcore: registered new device driver r8152-cfgselector
[    1.472310] usbcore: registered new interface driver r8152
[    1.477821] usbcore: registered new interface driver lan78xx
[    1.483502] usbcore: registered new interface driver smsc95xx
[    1.489317] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.495096] dwc_otg: FIQ enabled
[    1.495097] dwc_otg: NAK holdoff enabled
[    1.495098] dwc_otg: FIQ split-transaction FSM enabled
[    1.495100] Module dwc_common_port init
[    1.495207] usbcore: registered new interface driver uas
[    1.500542] usbcore: registered new interface driver usb-storage
[    1.506637] mousedev: PS/2 mouse device common for all mice
[    1.519841] rpi-rtc soc:rpi_rtc: registered as rtc0
[    1.526128] rpi-rtc soc:rpi_rtc: setting system clock to 1970-01-01T00:00:11 UTC (11)
[    1.534109] thermal_sys: Failed to register thermal zone cpu-thermal: -22
[    1.540927] bcm2711_thermal 107d542000.avs-monitor:thermal: error -EINVAL: could not register sensor: -22
[    1.550537] bcm2711_thermal 107d542000.avs-monitor:thermal: probe with driver bcm2711_thermal failed with error -22
[    1.561106] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
[    1.567660] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.576081] sdhci: Secure Digital Host Controller Interface driver
[    1.582302] sdhci: Copyright(c) Pierre Ossman
[    1.586709] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.592454] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.598946] hid: raw HID events driver (C) Jiri Kosina
[    1.604121] usbcore: registered new interface driver usbhid
[    1.609712] usbhid: USB HID core driver
[    1.613851] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 (0,8000003f) counters available
[    1.623370] NET: Registered PF_PACKET protocol family
[    1.628464] Key type dns_resolver registered
[    1.636344] registered taskstats version 1
[    1.640544] Loading compiled-in X.509 certificates
[    1.646885] Demotion targets for Node 0: null
[    1.651424] Key type .fscrypt registered
[    1.655407] Key type fscrypt-provisioning registered
[    1.662361] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    1.671182] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_probe: Success
[    1.678402] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    1.686815] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_probe: Success
[    1.693967] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    1.702382] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_probe: Success
[    1.709274] sdhci-brcmstb 1000fff000.mmc: Got CD GPIO
[    1.714784] of_cfs_init
[    1.717283] of_cfs_init: OK
[    1.720148] clk: Disabling unused clocks
[    1.732775] PM: genpd: Disabling unused power domains
[    1.755752] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
[    1.870498] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[    1.877310] mmcblk0: mmc0:aaaa SR64G 59.5 GiB
[    1.882883]  mmcblk0: p1 p2
[    1.885754] mmcblk0: mmc0:aaaa SR64G 59.5 GiB (quirks 0x00004000)
[    1.905761] mmc1: SDHCI controller on 1001100000.mmc [1001100000.mmc] using ADMA 64-bit
[    1.916583] Freeing unused kernel memory: 5440K
[    1.921259] Run /init as init process
[    1.924931]   with arguments:
[    1.924932]     /init
[    1.924933]   with environment:
[    1.924934]     HOME=/
[    1.924935]     TERM=linux
[    1.947032] mmc1: new ultra high speed DDR50 SDIO card at address 0001
[    2.239308] EXT4-fs (mmcblk0p2): mounted filesystem 7de846e5-f05a-4a3e-a95b-cb4e344a1d8c ro with ordered data mode. Quota mode: none.
[    2.518078] systemd[1]: System time before build time, advancing clock.
[    2.593157] NET: Registered PF_INET6 protocol family
[    2.598455] Segment Routing with IPv6
[    2.602140] In-situ OAM (IOAM) with IPv6
[    2.635021] systemd[1]: systemd 252.36-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    2.667871] systemd[1]: Detected architecture arm64.
[    2.683094] systemd[1]: Hostname set to <patchbox-001>.
[    3.014483] systemd[1]: multi-user.target: Found ordering cycle on patchbox-vnc.target/start
[    3.022983] systemd[1]: multi-user.target: Found dependency on patchbox-rpi-compat-graphical.service/start
[    3.032681] systemd[1]: multi-user.target: Found dependency on graphical.target/verify-active
[    3.041244] systemd[1]: multi-user.target: Found dependency on multi-user.target/start
[    3.049194] systemd[1]: multi-user.target: Job patchbox-vnc.target/start deleted to break ordering cycle starting with multi-user.target/start
[    3.062568] systemd[1]: Queued start job for default target graphical.target.
[    3.093876] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    3.101503] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    3.109638] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    3.121361] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[    3.132964] systemd[1]: Created slice user.slice - User and Session Slice.
[    3.142640] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    3.155282] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[    3.170622] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-39633f77\x2d01.device - /dev/disk/by-partuuid/39633f77-01...
[    3.184819] systemd[1]: Expecting device dev-dri-card0.device - /dev/dri/card0...
[    3.195207] systemd[1]: Expecting device dev-dri-renderD128.device - /dev/dri/renderD128...
[    3.206461] systemd[1]: Expecting device dev-ttyAMA10.device - /dev/ttyAMA10...
[    3.216698] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[    3.228479] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[    3.239034] systemd[1]: Reached target slices.target - Slice Units.
[    3.248193] systemd[1]: Reached target swap.target - Swaps.
[    3.256661] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[    3.268018] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[    3.279560] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    3.291322] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[    3.302386] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    3.314185] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[    3.324726] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    3.335269] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    3.346138] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    3.377325] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    3.387738] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    3.398472] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    3.408716] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[    3.428814] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[    3.440231] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    3.451684] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    3.463686] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[    3.475309] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[    3.486945] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    3.496987] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
[    3.497758] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    3.520196] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    3.531060] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[    3.542300] fuse: init (API version 7.41)
[    3.548152] systemd[1]: Starting patchbox-rpi-compat-early.service - Patchbox OS conditional paths service for compatibility between Pi models....
[    3.564227] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[    3.584984] systemd[1]: Starting systemd-journald.service - Journal Service...
[    3.596726] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    3.607978] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    3.620516] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    3.632763] systemd[1]: Started systemd-journald.service - Journal Service.
[    3.664595] EXT4-fs (mmcblk0p2): re-mounted 7de846e5-f05a-4a3e-a95b-cb4e344a1d8c r/w. Quota mode: none.
[    3.697119] systemd-journald[291]: Received client request to flush runtime journal.
[    3.720973] systemd-journald[291]: File /var/log/journal/5c98e9bdbe7940e884ccc70904af1c24/system.journal corrupted or uncleanly shut down, renaming and replacing.
Part 2:
[    4.232290] input: pwr_button as /devices/platform/pwr_button/input/input0
[    4.235822] rpi-gpiomem 107d508500.gpiomem: window base 0x107d508500 size 0x00000040
[    4.235965] rpi-gpiomem 107d508500.gpiomem: initialised 1 regions as /dev/gpiomem1
[    4.236144] brcmstb-i2c 107d508200.i2c:  @97500hz registered in interrupt mode
[    4.236261] brcmstb-i2c 107d508280.i2c:  @97500hz registered in interrupt mode
[    4.236721] rpi-gpiomem 107d517c00.gpiomem: window base 0x107d517c00 size 0x00000040
[    4.239198] rpi-gpiomem 107d517c00.gpiomem: initialised 1 regions as /dev/gpiomem2
[    4.239784] rpi-gpiomem 107d504100.gpiomem: window base 0x107d504100 size 0x00000020
[    4.240093] rpi-gpiomem 107d504100.gpiomem: initialised 1 regions as /dev/gpiomem3
[    4.241343] rpi-gpiomem 107d510700.gpiomem: window base 0x107d510700 size 0x00000020
[    4.241496] rpi-gpiomem 107d510700.gpiomem: initialised 1 regions as /dev/gpiomem4
[    4.252286] mc: Linux media interface: v0.10
[    4.285965] v3d 1002000000.v3d: error -EINVAL: invalid resource (null)
[    4.286386] v3d 1002000000.v3d: probe with driver v3d failed with error -22
[    4.326540] videodev: Linux video capture interface: v2.00
[    4.381574] pispbe 1000880000.pisp_be: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[    4.381582] pispbe 1000880000.pisp_be: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[    4.381587] pispbe 1000880000.pisp_be: bcm2712_iommu_device_group: MMU 1000005100.iommu
[    4.381592] pispbe 1000880000.pisp_be: Adding to iommu group 0
[    4.381596] pispbe 1000880000.pisp_be: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[    4.398224] pispbe 1000880000.pisp_be: Runtime PM usage count underflow!
[    4.416534] Bluetooth: Core ver 2.22
[    4.416565] NET: Registered PF_BLUETOOTH protocol family
[    4.416567] Bluetooth: HCI device and connection manager initialized
[    4.416574] Bluetooth: HCI socket layer initialized
[    4.416577] Bluetooth: L2CAP socket layer initialized
[    4.416582] Bluetooth: SCO socket layer initialized
[    4.431704] Bluetooth: HCI UART driver ver 2.3
[    4.431714] Bluetooth: HCI UART protocol H4 registered
[    4.431743] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    4.431855] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[    4.431893] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[    4.433921] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.444195] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[    4.444406] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[    4.444626] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.444816] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    4.447388] Bluetooth: HCI UART protocol Broadcom registered
[    4.709566] brcmfmac: F1 signature read @0x18000000=0x15264345
[    4.714825] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.715236] usbcore: registered new interface driver brcmfmac
[    4.721825] vc4-drm axi:gpu: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
[    4.721838] vc4-drm axi:gpu: bcm2712_iommu_probe_device: MMU 1000005200.iommu
[    4.721851] vc4-drm axi:gpu: bcm2712_iommu_device_group: MMU 1000005200.iommu
[    4.721861] vc4-drm axi:gpu: Adding to iommu group 1
[    4.721869] vc4-drm axi:gpu: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
[    4.726322] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[    4.728319] Registered IR keymap rc-cec
[    4.728395] rc rc0: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0
[    4.728449] input: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0/input1
[    4.731253] input: vc4-hdmi-0 HDMI Jack as /devices/platform/soc/107c701400.hdmi/sound/card0/input2
[    4.732315] vc4-drm axi:gpu: bound 107c701400.hdmi (ops vc4_hdmi_ops [vc4])
[    4.735179] Registered IR keymap rc-cec
[    4.735257] rc rc1: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1
[    4.735313] input: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1/input3
[    4.736798] input: vc4-hdmi-1 HDMI Jack as /devices/platform/soc/107c706400.hdmi/sound/card1/input4
[    4.737767] vc4-drm axi:gpu: bound 107c706400.hdmi (ops vc4_hdmi_ops [vc4])
[    4.737931] vc4-drm axi:gpu: bound 107c500000.mop (ops vc4_txp_ops [vc4])
[    4.737989] vc4-drm axi:gpu: bound 107c501000.moplet (ops vc4_txp_ops [vc4])
[    4.738038] vc4-drm axi:gpu: bound 107c410000.pixelvalve (ops vc4_crtc_ops [vc4])
[    4.738080] vc4-drm axi:gpu: bound 107c411000.pixelvalve (ops vc4_crtc_ops [vc4])
[    4.742202] [drm] Initialized vc4 0.0.0 for axi:gpu on minor 0
[    4.745146] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[    4.747773] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[    4.751414] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[    4.785778] Bluetooth: hci0: BCM: chip id 107
[    4.786042] Bluetooth: hci0: BCM: features 0x2f
[    4.787090] Bluetooth: hci0: BCM4345C0
[    4.787094] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[    4.811679] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.raspberrypi,5-model-b.hcd' Patch
[    4.907907] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[    4.908150] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Aug 29 2023 01:47:08 version 7.45.265 (28bca26 CY) FWID 01-b677b91b
[    5.206353] export_store: invalid GPIO 17
[    5.309881] Adding 204784k swap on /var/swap.  Priority:-2 extents:8 across:5840896k SS
[    5.521892] Bluetooth: hci0: BCM: features 0x2f
[    5.523218] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
[    5.523222] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[    5.523505] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
[    5.696408] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    5.696457] Bluetooth: BNEP filters: protocol multicast
[    5.696492] Bluetooth: BNEP socket layer initialized
[    5.712109] Bluetooth: MGMT ver 1.23
[    5.741781] NET: Registered PF_ALG protocol family
[    6.631150] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[   14.913338] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@120000 ranges:
[   14.913350] brcm-pcie 1000120000.pcie:   No bus range found for /axi/pcie@120000, using [bus 00-ff]
[   14.913358] brcm-pcie 1000120000.pcie:      MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
[   14.913363] brcm-pcie 1000120000.pcie:      MEM 0x1c00000000..0x1effffffff -> 0x0400000000
[   14.913369] brcm-pcie 1000120000.pcie:   IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
[   14.913372] brcm-pcie 1000120000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[   14.914956] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0000:00
[   14.914960] pci_bus 0000:00: root bus resource [bus 00-ff]
[   14.914963] pci_bus 0000:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
[   14.914966] pci_bus 0000:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
[   14.914979] pci 0000:00:00.0: [14e4:2712] type 01 class 0x060400 PCIe Root Port
[   14.914985] pci 0000:00:00.0: PCI bridge to [bus 00]
[   14.914988] pci 0000:00:00.0:   bridge window [mem 0x1f00000000-0x1f000fffff]
[   14.914991] pci 0000:00:00.0:   bridge window [mem 0x1f00000000-0x1f000fffff 64bit pref]
[   14.915007] pci 0000:00:00.0: PME# supported from D0 D3hot
[   14.915622] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[   15.017257] brcm-pcie 1000120000.pcie: clkreq-mode set to default
[   15.017267] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[   15.017294] pci 0000:01:00.0: [1de4:0001] type 00 class 0x020000 PCIe Endpoint
[   15.017310] pci 0000:01:00.0: BAR 0 [mem 0xffffc000-0xffffffff]
[   15.017317] pci 0000:01:00.0: BAR 1 [mem 0xffc00000-0xffffffff]
[   15.017326] pci 0000:01:00.0: BAR 2 [mem 0xffff0000-0xffffffff]
[   15.017396] pci 0000:01:00.0: supports D1
[   15.017399] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[   15.029264] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[   15.029282] pci 0000:00:00.0: bridge window [mem 0x1f00000000-0x1f005fffff]: assigned
[   15.029286] pci 0000:01:00.0: BAR 1 [mem 0x1f00000000-0x1f003fffff]: assigned
[   15.029291] pci 0000:01:00.0: BAR 2 [mem 0x1f00400000-0x1f0040ffff]: assigned
[   15.029295] pci 0000:01:00.0: BAR 0 [mem 0x1f00410000-0x1f00413fff]: assigned
[   15.029299] pci 0000:00:00.0: PCI bridge to [bus 01]
[   15.029301] pci 0000:00:00.0:   bridge window [mem 0x1f00000000-0x1f005fffff]
[   15.029304] pci_bus 0000:00: resource 4 [mem 0x1f00000000-0x1ffffffffb]
[   15.029306] pci_bus 0000:00: resource 5 [mem 0x1c00000000-0x1effffffff pref]
[   15.029309] pci_bus 0000:01: resource 1 [mem 0x1f00000000-0x1f005fffff]
[   15.029313] pci 0000:00:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[   15.029321] pci 0000:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[   15.029488] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[   15.029595] pcieport 0000:00:00.0: PME: Signaling with IRQ 60
[   15.029887] pcieport 0000:00:00.0: AER: enabled with IRQ 60
[   15.030021] rp1 0000:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
[   15.030025] rp1 0000:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
[   15.030039] rp1 0000:01:00.0: enabling device (0000 -> 0002)
[   15.030047] rp1 0000:01:00.0: pci_alloc_irq_vectors failed - -524
[   15.030052] rp1 0000:01:00.0: probe with driver rp1 failed with error -524
[   15.031841] platform cooling_fan: deferred probe pending: pwm-fan: Could not get PWM
[   15.031853] platform leds: deferred probe pending: leds-gpio: Failed to get GPIO '/leds/led-pwr'
[   15.031856] platform soc:sound: deferred probe pending: (reason unknown)
[   15.031857] platform cam0_reg: deferred probe pending: reg-fixed-voltage: can't get GPIO
[   15.031859] platform cam1_reg: deferred probe pending: reg-fixed-voltage: can't get GPIO
[   16.302744] Bluetooth: RFCOMM TTY layer initialized
[   16.302764] Bluetooth: RFCOMM socket layer initialized
[   16.302774] Bluetooth: RFCOMM ver 1.11
Looks like it is not attempting to load the Pisound driver. Normally, this is supposed to happen automatically, by Rasbperry Pi reading out the HAT EEPROM on Pisound, to know that it is attached and which driver to load.
Try running sudo dtoverlay pisound and see if the ALSA utilities now see the card.
Here it is,
patch@***:~ $ sudo dtoverlay pisound
* Failed to apply overlay '0_pisound-pi5' (kernel)
This failure seems to indicate, that the EEPROM was already read and the overlay applied, but still, I didn’t see any attempts to load the appropriate kernel module during your boot.
What is the output of:
modinfo snd_soc_pisound
patch@***:~ $ modinfo snd_soc_pisound
filename:       /lib/modules/6.12.25+rpt-rpi-2712/kernel/sound/soc/bcm/snd-soc-pisound.ko.xz
license:        GPL v2
description:    ASoC Driver for Pisound, https://blokas.io/pisound
author:         Giedrius Trainavicius <giedrius@blokas.io>
srcversion:     BB3B74CE93CF7FACECEDB24
alias:          of:N*T*Cblokaslabs,pisound-spiC*
alias:          of:N*T*Cblokaslabs,pisoundC*
depends:        snd-rawmidi,snd-soc-core,snd,snd-pcm
intree:         Y
vermagic:       6.12.25+rpt-rpi-2712 SMP preempt mod_unload modversions aarch64
Looks like you have updated the kernel version since the last dmesg output. Could you upload a fresh dmesg log?
Sorry, I did an upgrade in the meantime. Didn’t think it could be kernel specific.
Here is part 1:
patch@***:~ $ dmesg
[    0.000000] Linux version 6.12.25+rpt-rpi-2712 (serge@raspberrypi.com) (aarch64-linux-gnu-gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.12.25-1+rpt1 (2025-04-30)
[    0.000000] NODE_DATA(0) allocated [mem 0xffd98a00-0xffd9b7ff]
[    0.000000] ftrace: allocating 44908 entries in 44 pages
[    0.000127] printk: legacy console [tty1] enabled
[    0.000260] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[    0.000266] pid_max: default: 32768 minimum: 301
[    0.000288] LSM: initializing lsm=capability
[    0.000354] Mount-cache hash table entries: 8192 (order: 2, 65536 bytes, linear)
[    0.000368] Mountpoint-cache hash table entries: 8192 (order: 2, 65536 bytes, linear)
[    0.016012] rcu: Hierarchical SRCU implementation.
[    0.016026] rcu:     Max phase no-delay instances is 1000.
[    0.016085] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.020328] EFI services will not be available.
[    0.020401] smp: Bringing up secondary CPUs ...
[    0.024186] Detected PIPT I-cache on CPU1
[    0.024225] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
[    0.028091] Detected PIPT I-cache on CPU2
[    0.028121] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
[    0.032146] Detected PIPT I-cache on CPU3
[    0.032167] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
[    0.032195] smp: Brought up 1 node, 4 CPUs
[    0.032211] SMP: Total of 4 processors activated.
[    0.032214] CPU: All CPU(s) started at EL2
[    0.032217] CPU features: detected: 32-bit EL0 Support
[    0.032220] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.032224] CPU features: detected: Common not Private translations
[    0.032226] CPU features: detected: CRC32 instructions
[    0.032230] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.032232] CPU features: detected: LSE atomic instructions
[    0.032234] CPU features: detected: Privileged Access Never
[    0.032236] CPU features: detected: RAS Extension Support
[    0.032239] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.032264] alternatives: applying system-wide alternatives
[    0.033719] CPU features: detected: Hardware dirty bit management on CPU0-3
[    0.033864] Memory: 3784864K/4190208K available (13952K kernel code, 2264K rwdata, 4800K rodata, 5440K init, 647K bss, 70816K reserved, 327680K cma-reserved)
[    0.033995] devtmpfs: initialized
[    0.036055] Enabled cp15_barrier support
[    0.036065] Enabled setend support
[    0.036124] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.036135] futex hash table entries: 1024 (order: 2, 65536 bytes, linear)
[    0.036767] 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[    0.036773] 0 pages in range for non-PLT usage
[    0.036775] 129356 pages in range for PLT usage
[    0.036839] pinctrl core: initialized pinctrl subsystem
[    0.037000] DMI not present or invalid.
[    0.037614] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.037979] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.038034] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.038090] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.038108] audit: initializing netlink subsys (disabled)
[    0.038159] audit: type=2000 audit(0.000:1): state=initialized audit_enabled=0 res=1
[    0.038257] thermal_sys: Registered thermal governor 'step_wise'
[    0.038266] cpuidle: using governor menu
[    0.038314] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.038335] ASID allocator initialised with 32768 entries
[    0.038560] Serial: AMBA PL011 UART driver
[    0.039310] bcm2835-mbox 107c013880.mailbox: mailbox enabled
[    0.039564] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 15, base_baud = 0) is a PL011 rev2
[    0.039575] printk: legacy console [ttyAMA10] enabled
[    0.803219] raspberrypi-firmware soc:firmware: Attached to firmware from 2025-03-10T17:10:37, variant start_cd
[    0.817272] raspberrypi-firmware soc:firmware: Firmware hash is 2bb2ae6400000000000000000000000000000000
[    0.831790] /axi/interrupt-controller@7fff9000: Fixed dependency cycle(s) with /axi/interrupt-controller@7fff9000
[    0.846430] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
[    0.853775] iommu: Default domain type: Translated
[    0.858585] iommu: DMA domain TLB invalidation policy: strict mode
[    0.872281] SCSI subsystem initialized
[    0.876066] usbcore: registered new interface driver usbfs
[    0.881575] usbcore: registered new interface driver hub
[    0.886913] usbcore: registered new device driver usb
[    0.892049] pps_core: LinuxPPS API ver. 1 registered
[    0.897034] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.906205] PTP clock support registered
[    0.910394] vgaarb: loaded
[    0.913188] clocksource: Switched to clocksource arch_sys_counter
[    1.055725] VFS: Disk quotas dquot_6.6.0
[    1.059675] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
[    1.067929] NET: Registered PF_INET protocol family
[    1.072986] IP idents hash table entries: 65536 (order: 5, 524288 bytes, linear)
[    1.081576] tcp_listen_portaddr_hash hash table entries: 2048 (order: 1, 32768 bytes, linear)
[    1.090160] Table-perturb hash table entries: 65536 (order: 4, 262144 bytes, linear)
[    1.097938] TCP established hash table entries: 32768 (order: 4, 262144 bytes, linear)
[    1.105969] TCP bind hash table entries: 32768 (order: 6, 1048576 bytes, linear)
[    1.114177] TCP: Hash tables configured (established 32768 bind 32768)
[    1.120856] MPTCP token hash table entries: 4096 (order: 2, 98304 bytes, linear)
[    1.128353] UDP hash table entries: 2048 (order: 2, 65536 bytes, linear)
[    1.135111] UDP-Lite hash table entries: 2048 (order: 2, 65536 bytes, linear)
[    1.142355] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.148190] RPC: Registered named UNIX socket transport module.
[    1.154133] RPC: Registered udp transport module.
[    1.158850] RPC: Registered tcp transport module.
[    1.163567] RPC: Registered tcp-with-tls transport module.
[    1.169070] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.175548] PCI: CLS 0 bytes, default 64
[    1.179629] Trying to unpack rootfs image as initramfs...
[    1.186616] kvm [1]: nv: 554 coarse grained trap handlers
[    1.192243] kvm [1]: IPA Size Limit: 40 bits
[    1.196549] kvm [1]: GICV region size/alignment is unsafe, using trapping (reduced performance)
[    1.205393] kvm [1]: vgic interrupt IRQ9
[    1.209347] kvm [1]: VHE mode initialized successfully
[    1.221791] Initialise system trusted keyrings
[    1.226457] workingset: timestamp_bits=42 max_order=18 bucket_order=0
[    1.233378] NFS: Registering the id_resolver key type
[    1.238474] Key type id_resolver registered
[    1.242672] Key type id_legacy registered
[    1.246709] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.253440] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.261177] Key type asymmetric registered
[    1.265323] Asymmetric key parser 'x509' registered
[    1.270252] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.277798] io scheduler mq-deadline registered
[    1.282361] io scheduler kyber registered
[    1.286402] io scheduler bfq registered
[    1.290725] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7c502000, parent irq: 26)
[    1.299951] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d503000, parent irq: 27)
[    1.307722] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508380, parent irq: 28)
[    1.315484] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508400, parent irq: 29)
[    1.323256] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7d510600, parent irq: 30)
[    1.332396] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d517b00, parent irq: 31)
[    1.341864] ledtrig-cpu: registered to indicate activity on CPUs
[    1.372209] Freeing initrd memory: 16768K
[    1.406341] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[    1.412934] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 33, base_baud = 6000000) is a Broadcom BCM7271 UART
[    1.423543] serial serial0: tty port ttyS0 registered
[    1.428864] iproc-rng200 107d208000.rng: hwrng registered
[    1.434316] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
[    1.442780] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
[    1.451102] brd: module loaded
[    1.455130] loop: module loaded
[    1.458395] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.465740] Loading iSCSI transport class v2.0-870.
[    1.471338] usbcore: registered new interface driver lan78xx
[    1.477027] usbcore: registered new interface driver smsc95xx
[    1.482841] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.488619] dwc_otg: FIQ enabled
[    1.488621] dwc_otg: NAK holdoff enabled
[    1.488622] dwc_otg: FIQ split-transaction FSM enabled
[    1.488629] Module dwc_common_port init
[    1.488734] usbcore: registered new interface driver uas
[    1.494070] usbcore: registered new interface driver usb-storage
[    1.500162] mousedev: PS/2 mouse device common for all mice
[    1.513236] rpi-rtc soc:rpi_rtc: registered as rtc0
[    1.519509] rpi-rtc soc:rpi_rtc: setting system clock to 1970-01-01T00:00:11 UTC (11)
[    1.527494] thermal_sys: Failed to register thermal zone cpu-thermal: -22
[    1.534312] bcm2711_thermal 107d542000.avs-monitor:thermal: error -EINVAL: could not register sensor: -22
[    1.543921] bcm2711_thermal 107d542000.avs-monitor:thermal: probe with driver bcm2711_thermal failed with error -22
[    1.554491] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
[    1.561045] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.569433] sdhci: Secure Digital Host Controller Interface driver
[    1.575653] sdhci: Copyright(c) Pierre Ossman
[    1.580060] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.585807] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.592300] hid: raw HID events driver (C) Jiri Kosina
[    1.597474] usbcore: registered new interface driver usbhid
[    1.603065] usbhid: USB HID core driver
[    1.607200] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 (0,8000003f) counters available
[    1.616717] NET: Registered PF_PACKET protocol family
[    1.621812] Key type dns_resolver registered
[    1.629738] registered taskstats version 1
[    1.633921] Loading compiled-in X.509 certificates
[    1.640273] Demotion targets for Node 0: null
[    1.644815] Key type .fscrypt registered
[    1.649111] Key type fscrypt-provisioning registered
[    1.656025] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    1.664489] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_probe: Success
[    1.671741] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    1.680153] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_probe: Success
[    1.687286] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    1.695706] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_probe: Success
[    1.702939] sdhci-brcmstb 1000fff000.mmc: Got CD GPIO
[    1.703018] of_cfs_init
[    1.710521] of_cfs_init: OK
[    1.713376] clk: Disabling unused clocks
[    1.725825] PM: genpd: Disabling unused power domains
[    1.748990] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
[    1.860233] mmc0: new ultra high speed SDR104 SDXC card at address aaaa
[    1.867051] mmcblk0: mmc0:aaaa SR64G 59.5 GiB
[    1.872819]  mmcblk0: p1 p2
[    1.875699] mmcblk0: mmc0:aaaa SR64G 59.5 GiB (quirks 0x00004000)
[    1.897416] mmc1: SDHCI controller on 1001100000.mmc [1001100000.mmc] using ADMA 64-bit
[    1.908180] Freeing unused kernel memory: 5440K
[    1.912808] Run /init as init process
[    1.916481]   with arguments:
[    1.916482]     /init
[    1.916483]   with environment:
[    1.916484]     HOME=/
[    1.916485]     TERM=linux
[    1.937581] mmc1: new ultra high speed DDR50 SDIO card at address 0001
[    2.199624] EXT4-fs (mmcblk0p2): mounted filesystem 7de846e5-f05a-4a3e-a95b-cb4e344a1d8c ro with ordered data mode. Quota mode: none.
[    2.462915] systemd[1]: System time before build time, advancing clock.
[    2.537169] NET: Registered PF_INET6 protocol family
[    2.542467] Segment Routing with IPv6
[    2.546151] In-situ OAM (IOAM) with IPv6
[    2.578805] systemd[1]: systemd 252.36-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    2.611686] systemd[1]: Detected architecture arm64.
[    2.627525] systemd[1]: Hostname set to <***>.
[    2.979303] systemd[1]: multi-user.target: Found ordering cycle on patchbox-vnc.target/start
[    2.987800] systemd[1]: multi-user.target: Found dependency on patchbox-rpi-compat-graphical.service/start
[    2.997506] systemd[1]: multi-user.target: Found dependency on graphical.target/verify-active
[    3.006069] systemd[1]: multi-user.target: Found dependency on multi-user.target/start
[    3.014019] systemd[1]: multi-user.target: Job patchbox-vnc.target/start deleted to break ordering cycle starting with multi-user.target/start
[    3.027417] systemd[1]: Queued start job for default target graphical.target.
[    3.057880] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    3.065536] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    3.073698] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    3.085407] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[    3.097080] systemd[1]: Created slice user.slice - User and Session Slice.
[    3.105996] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    3.119409] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[    3.134736] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-39633f77\x2d01.device - /dev/disk/by-partuuid/39633f77-01...
[    3.148940] systemd[1]: Expecting device dev-dri-card0.device - /dev/dri/card0...
[    3.158541] systemd[1]: Expecting device dev-dri-renderD128.device - /dev/dri/renderD128...
[    3.169806] systemd[1]: Expecting device dev-ttyAMA10.device - /dev/ttyAMA10...
[    3.180034] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[    3.191814] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[    3.203153] systemd[1]: Reached target slices.target - Slice Units.
[    3.212319] systemd[1]: Reached target swap.target - Swaps.
[    3.220782] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[    3.232141] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[    3.243684] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    3.255436] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[    3.266575] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    3.278324] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[    3.289136] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    3.299404] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    3.309490] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    3.353301] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    3.363815] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    3.374574] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    3.384774] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[    3.405164] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[    3.416417] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    3.427780] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    3.439799] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[    3.451037] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[    3.462499] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    3.472881] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
[    3.473638] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    3.496605] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    3.507969] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[    3.519004] fuse: init (API version 7.41)
[    3.525233] systemd[1]: Starting patchbox-rpi-compat-early.service - Patchbox OS conditional paths service for compatibility between Pi models....
[    3.540349] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[    3.560980] systemd[1]: Starting systemd-journald.service - Journal Service...
[    3.575935] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    3.587052] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    3.599649] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    3.611198] systemd[1]: Started systemd-journald.service - Journal Service.
[    3.629099] EXT4-fs (mmcblk0p2): re-mounted 7de846e5-f05a-4a3e-a95b-cb4e344a1d8c r/w. Quota mode: none.
[    3.662662] systemd-journald[286]: Received client request to flush runtime journal.
[    3.704099] systemd-journald[286]: File /var/log/journal/5c98e9bdbe7940e884ccc70904af1c24/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    4.121944] input: pwr_button as /devices/platform/pwr_button/input/input0
[    4.126132] brcmstb-i2c 107d508200.i2c:  @97500hz registered in interrupt mode
[    4.128900] rpi-gpiomem 107d508500.gpiomem: window base 0x107d508500 size 0x00000040
[    4.129046] rpi-gpiomem 107d508500.gpiomem: initialised 1 regions as /dev/gpiomem1
[    4.129546] rpi-gpiomem 107d517c00.gpiomem: window base 0x107d517c00 size 0x00000040
[    4.130701] rpi-gpiomem 107d517c00.gpiomem: initialised 1 regions as /dev/gpiomem2
[    4.131408] mc: Linux media interface: v0.10
[    4.131514] brcmstb-i2c 107d508280.i2c:  @97500hz registered in interrupt mode
[    4.135996] rpi-gpiomem 107d504100.gpiomem: window base 0x107d504100 size 0x00000020
[    4.137557] rpi-gpiomem 107d504100.gpiomem: initialised 1 regions as /dev/gpiomem3
[    4.141906] rpi-gpiomem 107d510700.gpiomem: window base 0x107d510700 size 0x00000020
[    4.143214] rpi-gpiomem 107d510700.gpiomem: initialised 1 regions as /dev/gpiomem4
[    4.159616] v3d 1002000000.v3d: error -EINVAL: invalid resource (null)
[    4.159956] v3d 1002000000.v3d: probe with driver v3d failed with error -22
[    4.169775] videodev: Linux video capture interface: v2.00
[    4.264257] pispbe 1000880000.pisp_be: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[    4.264267] pispbe 1000880000.pisp_be: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[    4.264273] pispbe 1000880000.pisp_be: bcm2712_iommu_device_group: MMU 1000005100.iommu
[    4.264278] pispbe 1000880000.pisp_be: Adding to iommu group 0
[    4.264282] pispbe 1000880000.pisp_be: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[    4.265147] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.269694] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[    4.269908] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[    4.270757] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.270965] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    4.289227] pispbe 1000880000.pisp_be: Runtime PM usage count underflow!
[    4.328038] brcmfmac: F1 signature read @0x18000000=0x15264345
[    4.331409] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    4.342777] usbcore: registered new interface driver brcmfmac
[    4.380419] Bluetooth: Core ver 2.22
[    4.380604] NET: Registered PF_BLUETOOTH protocol family
[    4.380608] Bluetooth: HCI device and connection manager initialized
[    4.380617] Bluetooth: HCI socket layer initialized
[    4.380620] Bluetooth: L2CAP socket layer initialized
[    4.380626] Bluetooth: SCO socket layer initialized
[    4.410424] Bluetooth: HCI UART driver ver 2.3
[    4.410437] Bluetooth: HCI UART protocol H4 registered
[    4.410472] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    4.415583] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[    4.415644] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[    4.415761] Bluetooth: HCI UART protocol Broadcom registered
[    4.419468] vc4-drm axi:gpu: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
[    4.419477] vc4-drm axi:gpu: bcm2712_iommu_probe_device: MMU 1000005200.iommu
[    4.419577] vc4-drm axi:gpu: bcm2712_iommu_device_group: MMU 1000005200.iommu
[    4.420221] vc4-drm axi:gpu: Adding to iommu group 1
[    4.420229] vc4-drm axi:gpu: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
[    4.422537] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[    4.424474] Registered IR keymap rc-cec
[    4.424557] rc rc0: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0
[    4.424624] input: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0/input1
[    4.427174] input: vc4-hdmi-0 HDMI Jack as /devices/platform/soc/107c701400.hdmi/sound/card0/input2
[    4.428784] vc4-drm axi:gpu: bound 107c701400.hdmi (ops vc4_hdmi_ops [vc4])
[    4.430260] Registered IR keymap rc-cec
[    4.430321] rc rc1: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1
[    4.430385] input: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1/input3
[    4.433123] input: vc4-hdmi-1 HDMI Jack as /devices/platform/soc/107c706400.hdmi/sound/card1/input4
[    4.435334] vc4-drm axi:gpu: bound 107c706400.hdmi (ops vc4_hdmi_ops [vc4])
[    4.435575] vc4-drm axi:gpu: bound 107c500000.mop (ops vc4_txp_ops [vc4])
[    4.438670] vc4-drm axi:gpu: bound 107c501000.moplet (ops vc4_txp_ops [vc4])
[    4.438858] vc4-drm axi:gpu: bound 107c410000.pixelvalve (ops vc4_crtc_ops [vc4])
[    4.438982] vc4-drm axi:gpu: bound 107c411000.pixelvalve (ops vc4_crtc_ops [vc4])
[    4.441771] [drm] Initialized vc4 0.0.0 for axi:gpu on minor 0
[    4.444506] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[    4.448082] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[    4.451598] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[    4.663675] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[    4.663945] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Aug 29 2023 01:47:08 version 7.45.265 (28bca26 CY) FWID 01-b677b91b
[    4.765703] Bluetooth: hci0: BCM: chip id 107
[    4.765927] Bluetooth: hci0: BCM: features 0x2f
[    4.767036] Bluetooth: hci0: BCM4345C0
[    4.767043] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[    4.777934] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.raspberrypi,5-model-b.hcd' Patch
[    4.951366] export_store: invalid GPIO 17
[    5.052524] Adding 204784k swap on /var/swap.  Priority:-2 extents:8 across:5840896k SS
[    5.443536] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    5.443588] Bluetooth: BNEP filters: protocol multicast
[    5.443621] Bluetooth: BNEP socket layer initialized
[    5.464800] Bluetooth: hci0: BCM: features 0x2f
[    5.467903] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
[    5.467924] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[    5.469030] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
[    5.494371] Bluetooth: MGMT ver 1.23
[    5.518917] NET: Registered PF_ALG protocol family
[    6.437012] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
Part 2:
[   14.657330] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@120000 ranges:
[   14.657341] brcm-pcie 1000120000.pcie:   No bus range found for /axi/pcie@120000, using [bus 00-ff]
[   14.657350] brcm-pcie 1000120000.pcie:      MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
[   14.657354] brcm-pcie 1000120000.pcie:      MEM 0x1c00000000..0x1effffffff -> 0x0400000000
[   14.657360] brcm-pcie 1000120000.pcie:   IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
[   14.657364] brcm-pcie 1000120000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[   14.658927] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0000:00
[   14.658932] pci_bus 0000:00: root bus resource [bus 00-ff]
[   14.658934] pci_bus 0000:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
[   14.658937] pci_bus 0000:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
[   14.658949] pci 0000:00:00.0: [14e4:2712] type 01 class 0x060400 PCIe Root Port
[   14.658955] pci 0000:00:00.0: PCI bridge to [bus 00]
[   14.658958] pci 0000:00:00.0:   bridge window [mem 0x1f00000000-0x1f000fffff]
[   14.658961] pci 0000:00:00.0:   bridge window [mem 0x1f00000000-0x1f000fffff 64bit pref]
[   14.658977] pci 0000:00:00.0: PME# supported from D0 D3hot
[   14.659601] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[   14.761195] brcm-pcie 1000120000.pcie: clkreq-mode set to default
[   14.761201] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[   14.761225] pci 0000:01:00.0: [1de4:0001] type 00 class 0x020000 PCIe Endpoint
[   14.761239] pci 0000:01:00.0: BAR 0 [mem 0xffffc000-0xffffffff]
[   14.761246] pci 0000:01:00.0: BAR 1 [mem 0xffc00000-0xffffffff]
[   14.761252] pci 0000:01:00.0: BAR 2 [mem 0xffff0000-0xffffffff]
[   14.761316] pci 0000:01:00.0: supports D1
[   14.761318] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[   14.769198] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[   14.769208] pci 0000:00:00.0: bridge window [mem 0x1f00000000-0x1f005fffff]: assigned
[   14.769211] pci 0000:01:00.0: BAR 1 [mem 0x1f00000000-0x1f003fffff]: assigned
[   14.769215] pci 0000:01:00.0: BAR 2 [mem 0x1f00400000-0x1f0040ffff]: assigned
[   14.769219] pci 0000:01:00.0: BAR 0 [mem 0x1f00410000-0x1f00413fff]: assigned
[   14.769223] pci 0000:00:00.0: PCI bridge to [bus 01]
[   14.769225] pci 0000:00:00.0:   bridge window [mem 0x1f00000000-0x1f005fffff]
[   14.769228] pci_bus 0000:00: resource 4 [mem 0x1f00000000-0x1ffffffffb]
[   14.769230] pci_bus 0000:00: resource 5 [mem 0x1c00000000-0x1effffffff pref]
[   14.769232] pci_bus 0000:01: resource 1 [mem 0x1f00000000-0x1f005fffff]
[   14.769235] pci 0000:00:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[   14.769242] pci 0000:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[   14.769316] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[   14.769352] pcieport 0000:00:00.0: PME: Signaling with IRQ 60
[   14.769462] pcieport 0000:00:00.0: AER: enabled with IRQ 60
[   14.769569] rp1 0000:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
[   14.769576] rp1 0000:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
[   14.769588] rp1 0000:01:00.0: enabling device (0000 -> 0002)
[   14.769595] rp1 0000:01:00.0: pci_alloc_irq_vectors failed - -524
[   14.769597] rp1 0000:01:00.0: probe with driver rp1 failed with error -524
[   14.776182] platform cooling_fan: deferred probe pending: pwm-fan: Could not get PWM
[   14.776192] platform soc:sound: deferred probe pending: (reason unknown)
[   14.776194] platform leds: deferred probe pending: leds-gpio: Failed to get GPIO '/leds/led-pwr'
[   14.776196] platform cam1_reg: deferred probe pending: reg-fixed-voltage: can't get GPIO
[   25.329476] Bluetooth: RFCOMM TTY layer initialized
[   25.329494] Bluetooth: RFCOMM socket layer initialized
[   25.329504] Bluetooth: RFCOMM ver 1.11
That came later:
[   43.958687] Bluetooth: RFCOMM TTY layer initialized
[   43.958702] Bluetooth: RFCOMM socket layer initialized
[   43.958711] Bluetooth: RFCOMM ver 1.11
[   70.057237] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /axi/pcie@120000/rp1/spi@50000/status
[   70.057253] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /axi/pcie@120000/rp1/spi@50000/spidev@0/status
[   70.057259] OF: overlay: WARNING: memory leak will occur if overlay removed, property: /axi/pcie@120000/rp1/spi@50000/spidev@1/status
[   94.547210] export_store: invalid GPIO 17
[   94.578286] export_store: invalid GPIO 17
[   94.596615] export_store: invalid GPIO 17
Part 3:
license:        GPL v2
intree:         Y
Is the log complete? The first part has ~6.43… timestamped message as the last one, part 2 is already at ~14.66…
It would be best if you could upload the .log file using the upload button:
You can redirect the output of dmesg to file like this:
dmesg > dmesg.log
It will produce the log file in the current directory, most usually it’s the home directory.
This gap occurs with every restart. Don’t be surprised, I had switched off the system in the meantime.
dmesg.log (33.2 KB)
The kernel module for Pisound is not getting loaded, but it seems it’s available on your system.
What’s the output of:
cat /proc/device-tree/soc@*/sound/{compatible,status}
Also, if you have a spare SD card, could you try making a fresh OS install, and check if Pisounds work? Then we can be sure it’s some software configuration problem on your original SD.
The path /proc/device-tree/soc@*/ don’t exist.
Here ist the output:
patch@**:~ $ cat /proc/device-tree/soc@*/sound/{compatible,status}
cat: '/proc/device-tree/soc@*/sound/compatible': Datei oder Verzeichnis nicht gefunden
cat: '/proc/device-tree/soc@*/sound/status': Datei oder Verzeichnis nicht gefunden
patch@**:~ $ /proc/device-tree/
aliases/         cam0_reg/        chosen/          cooling_fan/     hvs@107c580000/  memory@0/        psci/            sd_io_1v8_reg/   system/
arm-pmu/         cam1_clk/        clk-108M/        cpus/            i2c0if/          __overrides__/   pwr_button/      sd_vcc_reg/      thermal-zones/
axi/             cam1_reg/        clk-27M/         dummy/           i2c0mux/         pcm5102a-codec/  reserved-memory/ soc/             timer/
cam0_clk/        cam_dummy_reg/   clocks/          hat/             leds/            phy/             rp1_vdd_3v3/     __symbols__/     wl_on_reg/
patch@***:~ $ /proc/device-tree/soc/
avs-monitor@7d542000/          gpiomem@7d504100/              i2c@7d005e00/                  intc@7d517ac0/                 pixelvalve@7c410000/           serial@7d50c000/
axiperf/                       gpiomem@7d508500/              i2c@7d508200/                  intc@7d517b00/                 pixelvalve@7c411000/           serial@7d50d000/
clock@7c700000/                gpiomem@7d510700/              i2c@7d508280/                  interrupt-controller@7c502000/ power/                         sound/
cprman@7d202000/               gpiomem@7d517c00/              i2c@7d508300/                  interrupt-controller@7d510600/ pwm@7d00c000/                  spi@7d004000/
fb/                            hdmi@7ef00700/                 i2c@7d517a00/                  local_intc@7cd00000/           pwm@7d00c800/                  spi@7d004600/
firmware/                      hdmi@7ef05700/                 i2c@7d544000/                  mailbox@7c013880/              pwm@7d517a80/                  spi@7d004800/
firmwarekms@7d503000/          i2c@7d005000/                  _i2s@7d003000/                 mmc@7d002000/                  rng@7d208000/                  spi@7d004a00/
fixedregulator_3v3/            i2c@7d005600/                  intc@7d503000/                 mop@7c500000/                  rpi_rtc/                       spi@7d004c00/
fixedregulator_5v0/            i2c@7d005800/                  intc@7d508380/                 moplet@7c501000/               serial@7d001000/               timer@7c003000/
gpio@7d508500/                 i2c@7d005a00/                  intc@7d508400/                 pinctrl@7d504100/              serial@7d001400/               watchdog@7d200000/
gpio@7d517c00/                 i2c@7d005c00/                  intc@7d517000/                 pinctrl@7d510700/              serial@7d001a00/
patch@****:~ $
I should have a SD Card in spare. Will try it and hope that both pisound are not ruined.
Interesting. Try running this:
grep -rHn pisound /proc/device-tree
patch@patchbox-001:~ $ grep -rHn pisound /proc/device-tree
grep: /proc/device-tree/soc/sound/compatible: Übereinstimmungen in Binärdatei
grep: /proc/device-tree/axi/pcie@120000/rp1/spi@50000/pisound_spi@0/compatible: Übereinstimmungen in Binärdatei
grep: /proc/device-tree/axi/pcie@120000/rp1/spi@50000/pisound_spi@0/name: Übereinstimmungen in Binärdatei
grep: /proc/device-tree/axi/pcie@120000/rp1/gpio@d0000/pisound_button_pins/name: Übereinstimmungen in Binärdatei
And:
cat /proc/device-tree/soc/sound/status
