Hi there,
I’m new to this community. I have a Roland SPD 30 going through midihub to a microkorg2. Out of the 8 pads available, I used 4 pads to create a different chord with each pad. A little background is the SPD 30 transmits true note value. I also have a dp 10 plugged into the hihat ctrl input to create cc64 sustain on each chord when the pedal is pressed. I was successful in creating a pipeline with range filter, rescale, harmonizer and sustain in the pipeline. When the pedal is pressed the chord sustains and stops sustain when the pedal not pressed. The sound stops from one pad and started on the new pad when a different pad is hit, so there is no stacking of the chords when multiple pads are hit.
My goal is to use the 4 remaining pads to create different effects on the chord that is sustained. Every time I try to ask chat gpt or copilot to help with the pipeline, the effect is on the chord pads, bleeding into the chords and has no change when the effects pad is hit.
Can anyone offer some suggestions that might point me in the correct direction to make this possible? Hopefully this is not an impossible goal to reach.
