System is 16 GB Raspberry Pi 5 running latest PiOS. I installed the Pisound software and did sudo pisound-config. When I select “Change Pisound Hotspot Settings”, I get a Python traceback:
❯ sudo pisound-config
File "/usr/local/pisound/pisound-config/main.py", line 177, in <module>
loop.run()
File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 287, in run
self._run()
File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 385, in _run
self.event_loop.run()
File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 790, in run
self._loop()
File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 827, in _loop
self._watch_files[fd]()
File "/usr/lib/python3/dist-packages/urwid/raw_display.py", line 416, in <lambda>
wrapper = lambda: self.parse_input(
File "/usr/lib/python3/dist-packages/urwid/raw_display.py", line 515, in parse_input
callback(processed, processed_codes)
File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 412, in _update
self.process_input(keys)
File "/usr/lib/python3/dist-packages/urwid/main_loop.py", line 513, in process_input
k = self._topmost_widget.keypress(self.screen_size, k)
File "/usr/lib/python3/dist-packages/urwid/decoration.py", line 840, in keypress
return self._original_widget.keypress((maxcol,maxrow-top-bottom), key)
File "/usr/lib/python3/dist-packages/urwid/decoration.py", line 622, in keypress
return self._original_widget.keypress(maxvals, key)
File "/usr/lib/python3/dist-packages/urwid/container.py", line 1135, in keypress
return self.body.keypress( (maxcol, remaining), key )
File "/usr/lib/python3/dist-packages/urwid/listbox.py", line 968, in keypress
key = focus_widget.keypress((maxcol,),key)
File "/usr/lib/python3/dist-packages/urwid/wimp.py", line 543, in keypress
self._emit('click')
File "/usr/lib/python3/dist-packages/urwid/widget.py", line 461, in _emit
signals.emit_signal(self, name, self, *args)
File "/usr/lib/python3/dist-packages/urwid/signals.py", line 265, in emit
result |= self._call_callback(callback, user_arg, user_args, args)
File "/usr/lib/python3/dist-packages/urwid/signals.py", line 295, in _call_callback
return bool(callback(*args_to_pass))
File "/usr/local/pisound/pisound-config/main.py", line 82, in hs_menu
items = values.get_hs_config()
File "/usr/local/pisound/pisound-config/values.py", line 90, in get_hs_config
with open(settings.HS_CFG, 'r') as f:
FileNotFoundError: [Errno 2] No such file or directory: '/etc/hostapd/hostapd.conf'
That configuration file belongs to the package “hostapd”, which is not installed. My guess is that the Raspberry Pi OS changed their WiFi user tooling and there’s a different way to configure hotspots now.
