I’m trying to find out how to setup a kind of midi patch pipeline controlled by CC for creating layered sounds. I would like to be able to enable and disable (toggle) midi communication for specific given channels using CC.
Basically, a keyboard connected to a multitimbral sound module, with the Midihub inbetween controlled by buttons on a midi control surface sending CCs to control the channel communication making it possible to play specific multiple midi channels on the module simultaneously.
This is pretty straightforward to do if you have a pipeline per ‘layer’ or channel and then selective enable and disable those pipelines using the Bypass function mapped to the external MIDI controller surface.
I show how to do this in my video here. I used a Minilab with pads as a controller to selectively enable and disable layers in the Midihub. In a previous video I show how to use a Faderfox EC4 to do similar: https://youtu.be/zHD1na8Nmso
