Values for ON / OFF messages and percent and other messages
Hey, what’s the value range for Midihub’s on/off or bypass commands?
0 off, 1-127 on?
or 0-63 off 64-127 on?
and for commands that are measured in percent - like chance or swing - is the range 0-127 or is it 0-100?
or for something like the arp repetitions command - is it 0-127 or 0-15?
Trying to program my knob controller (faderfox EC4) and could definitely use a chart with all the values for all the pipe parameters! Is there one somewhere?
Midihub’s on/off or bypass commands…
…0-63 off 64-127 on?
Yes
… arp repetitions command - is it 0-127 or 0-15?
CC value range 0-127 will map to 0-100, 1-16, or whatever the property value range is in a “rounded integer” fashion.
(ie. every input value will map to something)
Don’t think so. Never gone looking.
There may be a precise definition of above rule somewhere but, again, Never gone looking.
ah, I was hoping it wouldn’t be that way, as it’s easier to know what setting i’ve chosen if it’s 1-15 type of values, but not the end of the world!
thank you!
I guess the underlying thinking is that many people have non-configurable controls and that small movement mapped to properties with small ranges could lead to accidental jumps.
If it remains an issue for you, maybe consider a loopback with a Rescale Pipe?
yeah it seems l
yes, that makes sense, and it’s just simple one size fits all way that works.
for the loopback with rescale, i dont think that would make sense, though maybe i misunderstand what rescale does - doesn’t it just affect notes, not CC ranges?
but maybe a midi range filter? but i honestly cant figure out exactly how that pipe works at the moment either.
i would be rally handy for a setting like octave range for the arp if i could squish the 0-127 into 0-4 range (or however many octaves are the max) but i guess my situation is a bit unusual
Sounds a bit like you’re trying to think out your solutions without a Midihub to hand; have you got one yet?
If not it might be better to read bit at bottom when you can get hands-on.
In the meantime –if there’s a spare in&out– feel confident you can get Midihub to do the above…
…or even something fancier like switching between just 4 arp types of your choice!
(some day Midihub will do this natively but for now loopback is what some users use get Midihub to respond to scaled mapping values)
EDIT:
just looked at this again.
But this is what it does, right?
  • CC value → Octave Range
  • {0 - 9} → -7
  • {10- 19} → -6
  • {54- 63} → -1
  • {64- 73} → +0
  • {117-126} → +6
  • {127} → -7
You only need to get fancy if you want your {0-127} to sweep over say -2 to +4 octaves
try it yourself bit:
No, you can Choose from:
Screen Shot 2023-02-27 at 09.33.20
The sticky bit is not that, but fact that mappings are always taken as direct inputs.
See explanation of “direct-ness” of mappings and how to get around it
i do actually have one! was writing that message while away from home though - and hadn’t played with rescale because I had misunderstood that it was just for note messages from reading the manual section.
ooh thanks, ok yes this looks right - but why would i need to loopback, i can’t just put the rescale pipe after the arp pipe?
and for switching between arp types, we can already do that by mapping a knob to the arp type function - what do you mean?
cos midihub doesn’t care what you do with the map value once it’s in the hub only its value as it comes into a physical port; see the explanation link
indeed, but imagine for a performance, you wanted only
  • Up and Down
  • Up and Down Incl.
  • Low Up and Down
  • Low Up
then loopback means you can do this.
(ie. “switching between just 4 arp types of your choice”)
otherwise you’d need a knob that can be configured to give 4 specific non-adjacent values
or 4 toggle buttons each set to a different value
or run the risk of turning to an arp-type you don’t want mid-gig!
i think i understand, but i’m going to have to play with it and see if I can get my head around this, but might come back here to bug you to explain more if I can’t figure it out - thanks for your help
and by loopback you mean physically take a cable from like out A to in B, or can i do that by sticking in a MIDI in pipe?
Yes like in the pic here or if you’re connected via a computer via a patchbay
