this happens when the osc address is not correct.
note: you need to reload the lemur project for it to pickup the new address !!
(this catches everyone out!)
the network name is
patchbox.
note: the full stop after patchbox, it won’t work without it.
(that or as @Giedrius pointed out you can use the ip address)
lemur template already has the port, its 6100.
(its just its defaulted to organelle as a hostname)
@Taubaland , odd , my push2 was ok a couple of days ago when I tried… (I’ll check it again)
@Makrotulpa, yes hostname needs changing in the msg box , where indicated.
(patchbox. works for me)
… make sure you have mec running
single click of button, and the leds will flash once to show its activated.
