Note HOLD (monophonic/polyponic)
I have a MIDI keyboard without note Hold function and there is also no possibility on the synth to midi map a hold button.
I would like to use a button (note or cc) on a midi controller to act as hold button for the notes coming from the MIDI keyboard. And optionally a second button to select which 2 scenario: monophonic hold and polyphonic hold.
  1. for monophonic use:
  • when the the hold button is enabled: when pressing a key, all other notes must be switched off first. only 1 note can be active at the same time, the last one.
  • when releasing the hold button: all notes must be switched off.
  1. optional, for polyphonic use:
  • as long as the hold button is pressed: all notes that were on when the button was pressed must stay active and any new played notes as well.
Is that possible with midihub?
What happens if other notes are playing when the hold button is enabled? all note_off?
Does each new note_on then send a note_off for the previous note?
Presumably all the notes are on one channel?
Dep on answers to above, seems like a physical-loopback scenario (to get MH to map to itself to store the current note number): have you worked with loopbacks?
Piece of cake. Just use the sustain pipe and map a key or button to sustain on. To do a on off toggle you need to do a loopback but a pretty simple one. Otherwise the sustain will be momentary(on as long as you are pressing down). If you are using a knob, there is no need for a loopback.
Same thing for poly/mono but map the “Mode” argument. If your controller buttons can be set to toggle or you can set the value it sends then you won’t need to use a loopback unless you want to use your keyboard notes.
Thank you for your reply. Good remark about the channels. A hold per channel will allow me to keep notes on on several channels when swithing the channel on my keyboard. And I will also map an emergency button do disable all notes and also all arpeggiators on the synths.
Ha, ambitious; I was asking in hope of keeping everything as simple as possible!
for a single channel, monophonic solution, I was thinking of using the same loopback strategy as this PC change patch, in that each new note triggers a Transform which creates the “previous” note_off.
Thank you for your reply. Indeed piece of cake. I was searching in wrong direction. The sustain pipe in chord mode is what I was looking for. It works for both scenario’s. I am going to use a toggle switch to enable/disable the sustain. And because the solution is so easy, I will map 1 sustain per channel, for more flexibility.
ha! didn’t mention Sustain cos I thought your specs precluded it and so you’d already rejected that!
