There is no pisound audio from latest Sonic Pi. This sw uses standard HMI audio, don’t ask me why…it connects via PipeWire (qpwgraph) with internal headphones, USB audio soundcard but no pisound. Pisound is presented as “PS-048CA3j snd-soc-dummy-dai-0-playback_FL” in qpwgraph. Do I need some sort of driver or special script? I use Patchbox OS. Anyone has the same problem? Looking for a solution, thank you.
Additional info: this is with Patchbox OS 2024. I have installed Patchbox OS 2022 first release and it is working fine with Sonic Pi v3.3.1.
Also strange that Sonic Pi is not longer in the install package of 2024 version…I think still Pipewire is the problem. Please respond to this topic.
There were some issues with the .deb availability or runtime problem at the time the OS image was being built.
Can you use Jack backend instead of pipewire?
