I’d like a block you could drop in to split the midi stream into two identical streams, then on output stream B anything I selected would be removed from output stream A and vice versa, so if they were re combined, they would be identical to the input stream.
Terminology differs, but it sounds quite a bit like what I suggested here: Filter to target pipe, aka Y pipe
And there was me thinking I had had my very first original thought…oh well.
