Hello !!
I have a raspberry 5 for a short time, and a try patchboxos bookworm for use my pure data patch.
When I setting Patchbox → module → pure data patch the console sent this message
Service: pisound-ctl.service enabled Service: pisound-ctl.service started Skipping enabling touchosc2midi.service, because it is masked. Unmask it by running `sudo systemctl unmask touchosc2midi.service` /etc/amidiminder.rules -> None Traceback (most recent call last): File "/usr/bin/patchbox", line 33, in sys.exit(load_entry_point('patchbox-cli==1.4.0', 'console_scripts', 'patchbox')()) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/click/core.py", line 1130, in __call__ return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/click/core.py", line 1055, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/click/core.py", line 1635, in invoke rv = super().invoke(ctx) ^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/click/core.py", line 1404, in invoke return ctx.invoke(self.callback, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/click/core.py", line 760, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/click/decorators.py", line 26, in new_func return f(get_current_context(), *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/patchbox/cli.py", line 40, in cli do_group_menu(ctx, cancel='Exit') File "/usr/lib/python3/dist-packages/patchbox/utils.py", line 203, in do_group_menu ctx.invoke(ctx.command.get_command(ctx, cmd)) File "/usr/lib/python3/dist-packages/click/core.py", line 760, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/click/decorators.py", line 26, in new_func return f(get_current_context(), *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/patchbox/modules/jack/cli.py", line 129, in cli do_group_menu(ctx) File "/usr/lib/python3/dist-packages/patchbox/utils.py", line 203, in do_group_menu ctx.invoke(ctx.command.get_command(ctx, cmd)) File "/usr/lib/python3/dist-packages/click/core.py", line 760, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/patchbox/modules/jack/cli.py", line 150, in restart do_go_back_if_ineractive() File "/usr/lib/python3/dist-packages/patchbox/utils.py", line 280, in do_go_back_if_ineractive ctx.invoke(context.command) File "/usr/lib/python3/dist-packages/click/core.py", line 760, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/click/decorators.py", line 26, in new_func return f(get_current_context(), *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/patchbox/modules/jack/cli.py", line 129, in cli do_group_menu(ctx) File "/usr/lib/python3/dist-packages/patchbox/utils.py", line 196, in do_group_menu go_home_or_exit(ctx) File "/usr/lib/python3/dist-packages/patchbox/utils.py", line 172, in go_home_or_exit ctx.invoke(context.parent.command) File "/usr/lib/python3/dist-packages/click/core.py", line 760, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/click/decorators.py", line 26, in new_func return f(get_current_context(), *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/patchbox/cli.py", line 40, in cli do_group_menu(ctx, cancel='Exit') File "/usr/lib/python3/dist-packages/patchbox/utils.py", line 203, in do_group_menu ctx.invoke(ctx.command.get_command(ctx, cmd)) File "/usr/lib/python3/dist-packages/click/core.py", line 760, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/click/decorators.py", line 26, in new_func return f(get_current_context(), *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/patchbox/modules/module/cli.py", line 33, in cli ctx.invoke(ctx.command.get_command(ctx, 'config')) File "/usr/lib/python3/dist-packages/click/core.py", line 760, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/click/decorators.py", line 26, in new_func return f(get_current_context(), *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/patchbox/modules/module/cli.py", line 185, in config manager.activate(module, autolaunch=False, autoinstall=True) File "/usr/lib/python3/dist-packages/patchbox/module.py", line 646, in activate self._activate_module(module, update_env) File "/usr/lib/python3/dist-packages/patchbox/module.py", line 662, in _activate_module self._service_manager.enable_start_unit(service) File "/usr/lib/python3/dist-packages/patchbox/service.py", line 123, in enable_start_unit if get_handler_for_service(pservice).handle_activate(pservice): ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/patchbox/service.py", line 43, in handle_activate return PatchboxSymbolicLinkConfHandler.update_symlink(service.environ_value, self.conf_file) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/patchbox/service.py", line 38, in update_symlink symlink(src, dst) TypeError: symlink: src should be string, bytes or os.PathLike, not NoneType
I follow this topic [Beta] Patchbox OS Bookworm ARM64 2024-04-04 - #5 by redcloud"
but i don’t launch my pure data patch.
Are they a solution at this problem actualy ??
Thank
Jérôme
