Arpeggiator Detail
Hi there, I just have bought an Arturia KeyLab 61 and the only thing I really like is the very musical arpeggiator in this case:
Description:
  • Hold-function
  • When chords are set, it plays the cords, easy.
  • But, when a new chord or note is set, it does not add these to the former but clears and takes the new note or cord.
  • this leaves to me in live-situation some very musical freedom
Question:
How can I rebuild this in the Midihub-MIDI-Editor?
Thanks in advance!
a lot depends on the detail of
  • Hold-function
This lw_chordArp.mhp is a very rough starting point with many shortcomings
(velocity springs to mind!)
but it’ll hopefully show what else needs to be built in to make it closer to your beloved :wink: KeyLab…
Thanks a lot for your helpful reply. Will have a look at it in short! Probably a good ground to give my Keylab back :slight_smile:
Not quite yet but you should consider a career in Arturia’s marketing department…
Give the Chrod mode of Sustain pipe a try too, it will switch to a new chord after all the keys were let go and a new one is being played without having to retrigger the Pedal On.
I’ll do – great adding – thanks a lot!
@lloyd-weena, forget my early version (I misunderstood Chord in Sustain); as @Giedrius (so politely!) hints, you don’t need anything so complicated
lw_chordArpSimpler!
