Sostenuto implementation & Question regarding virtual loopback
This first line of this posted by @JoeyButters …
…can be used for any number of Transforms in the same pipeline:
Each new Transform would be assigned to a different note…
..then, as I said in post 5 above:
So, if you include the “pre-Transforms” filter (for future-proofing), your entire bank of toggles can be done with
(5 + # of toggles) number of pipes
And don’t forget,
  • some can be ‘On → Off’ instead of ‘Off → On’
  • you might re-use same toggle (turning off a bunch of inputs is common)
