Pisound-btn failed writing to /sys/class/gpio/export
Raspberry Pi 5, while testing PiSound, I can’t use button.
Built pisound-btn from git clone, /usr/local/bin/pisound-btn can’t write to /sys/class/gpio/export
Does anyone get the button to work?
What is the output of:
ls -la /sys/class/gpio/
total 0
drwxrwxr-x  2 root gpio     0 Jan  5 20:19 .
drwxr-xr-x 71 root root     0 Jan  5 20:19 ..
--w--w----  1 root gpio 16384 Jan  5 20:19 export
lrwxrwxrwx  1 root root     0 Jan  5 20:19 gpio416 -> ../../devices/platform/axi/1000120000.pcie/1f000d0000.gpio/gpiochip4/gpio/gpio416
lrwxrwxrwx  1 root gpio     0 Jan  5 20:19 gpiochip399 -> ../../devices/platform/axi/1000120000.pcie/1f000d0000.gpio/gpio/gpiochip399
lrwxrwxrwx  1 root gpio     0 Jan  5 20:19 gpiochip453 -> ../../devices/platform/soc/107d517c00.gpio/gpio/gpiochip453
lrwxrwxrwx  1 root gpio     0 Jan  5 20:19 gpiochip459 -> ../../devices/platform/soc/107d517c00.gpio/gpio/gpiochip459
lrwxrwxrwx  1 root gpio     0 Jan  5 20:19 gpiochip476 -> ../../devices/platform/soc/107d508500.gpio/gpio/gpiochip476
lrwxrwxrwx  1 root gpio     0 Jan  5 20:19 gpiochip480 -> ../../devices/platform/soc/107d508500.gpio/gpio/gpiochip480
--w--w----  1 root gpio 16384 Jan  5 20:19 unexport
Are you trying to run pisound-btn as the regular user? Is it member of the group gpio?
What is the output of groups and whoami?
As the regular user ,
Failed writing to /sys/class/gpio/export! Error 22.
I’m a member of the gpio, and
cat /etc/group
gpio:x:993:ME
systemctl status
× pisound-btn.service - Pisound button daemon autostart
     Loaded: loaded (/lib/systemd/system/pisound-btn.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Fri 2024-01-05 20:19:15 KST; 18min ago
   Duration: 105ms
    Process: 933 ExecStart=/usr/local/bin/pisound-btn (code=exited, status=255/EXCEPTION)
   Main PID: 933 (code=exited, status=255/EXCEPTION)
        CPU: 2ms
Jan 05 20:19:15 host systemd[1]: Started pisound-btn.service - Pisound button daemon autostart.
Jan 05 20:19:15 host pisound-btn[933]: Failed writing to /sys/class/gpio/export! Error 22.
Jan 05 20:19:15 host systemd[1]: pisound-btn.service: Main process exited, code=exited, status=255/EXCEPTION
Jan 05 20:19:15 host systemd[1]: pisound-btn.service: Failed with result 'exit-code'.
Looks like the pin numbering got changed on Raspberry Pi 5:
https://forums.raspberrypi.com/viewtopic.php?p=2165403&sid=bcd2e8809999364ea1e36e7286ef5cc3#p2165403
Please post the output of cat /sys/kernel/debug/gpio
gpiochip4: GPIOs 399-452, parent: platform/1f000d0000.gpio, pinctrl-rp1:
 gpio-399 (ID_SD               )
 gpio-400 (ID_SC               )
 gpio-401 (PIN3                )
 gpio-402 (PIN5                )
 gpio-403 (PIN7                )
 gpio-404 (PIN29               )
 gpio-405 (PIN31               )
 gpio-406 (PIN26               |spi0 CS1            ) out hi ACTIVE LOW
 gpio-407 (PIN24               |spi0 CS0            ) out hi ACTIVE LOW
 gpio-408 (PIN21               )
 gpio-409 (PIN19               )
 gpio-410 (PIN23               )
 gpio-411 (PIN32               |reset               ) out hi
 gpio-412 (PIN33               |osr                 ) out hi
 gpio-413 (PIN8                )
 gpio-414 (PIN10               )
 gpio-415 (PIN36               |osr                 ) out lo
 gpio-416 (PIN11               |button              ) in  hi ACTIVE LOW
 gpio-417 (PIN12               )
 gpio-418 (PIN35               )
 gpio-419 (PIN38               )
 gpio-420 (PIN40               )
 gpio-421 (PIN15               )
 gpio-422 (PIN16               )
 gpio-423 (PIN18               |reset               ) out hi
 gpio-424 (PIN22               |data_available      ) in  lo
 gpio-425 (PIN37               |osr                 ) out lo
 gpio-426 (PIN13               )
 gpio-427 (PCIE_RP1_WAKE       )
 gpio-428 (FAN_TACH            )
 gpio-429 (HOST_SDA            )
 gpio-430 (HOST_SCL            )
 gpio-431 (ETH_RST_N           |phy-reset           ) out hi ACTIVE LOW
 gpio-432 (-                   )
 gpio-433 (CD0_IO0_MICCLK      |cam0_reg            ) out lo
 gpio-434 (CD0_IO0_MICDAT0     )
 gpio-435 (RP1_PCIE_CLKREQ_N   )
 gpio-436 (-                   )
 gpio-437 (CD0_SDA             )
 gpio-438 (CD0_SCL             )
 gpio-439 (CD1_SDA             )
 gpio-440 (CD1_SCL             )
 gpio-441 (USB_VBUS_EN         )
 gpio-442 (USB_OC_N            )
 gpio-443 (RP1_STAT_LED        |PWR                 ) out hi ACTIVE LOW
 gpio-444 (FAN_PWM             )
 gpio-445 (CD1_IO0_MICCLK      |cam1_reg            ) out lo
 gpio-446 (2712_WAKE           )
 gpio-447 (CD1_IO1_MICDAT1     )
 gpio-448 (EN_MAX_USB_CUR      )
 gpio-449 (-                   )
 gpio-450 (-                   )
 gpio-451 (-                   )
 gpio-452 (-                   )
gpiochip3: GPIOs 453-458, parent: platform/107d517c00.gpio, gpio-brcmstb@107d517c20:
 gpio-453 (HDMI0_SCL           )
 gpio-454 (HDMI0_SDA           )
 gpio-455 (HDMI1_SCL           )
 gpio-456 (HDMI1_SDA           )
 gpio-457 (PMIC_SCL            )
 gpio-458 (PMIC_SDA            )
gpiochip2: GPIOs 459-475, parent: platform/107d517c00.gpio, gpio-brcmstb@107d517c00:
 gpio-459 (RP1_SDA             )
 gpio-460 (RP1_SCL             )
 gpio-461 (RP1_RUN             |RP1 RUN pin         ) out hi
 gpio-462 (SD_IOVDD_SEL        |vdd-sd-io           ) out hi
 gpio-463 (SD_PWR_ON           |sd_vcc_reg          ) out hi
 gpio-464 (SD_CDET_N           )
 gpio-465 (SD_FLG_N            )
 gpio-466 (-                   )
 gpio-467 (2712_WAKE           )
 gpio-468 (2712_STAT_LED       |ACT                 ) out hi ACTIVE LOW
 gpio-469 (-                   )
 gpio-470 (-                   )
 gpio-471 (PMIC_INT            )
 gpio-472 (UART_TX_FS          )
 gpio-473 (UART_RX_FS          )
 gpio-474 (-                   )
 gpio-475 (-                   )
gpiochip1: GPIOs 476-479, parent: platform/107d508500.gpio, gpio-brcmstb@107d508520:
 gpio-476 (WIFI_SDIO_D0        )
 gpio-477 (WIFI_SDIO_D1        )
 gpio-478 (WIFI_SDIO_D2        )
 gpio-479 (WIFI_SDIO_D3        )
gpiochip0: GPIOs 480-511, parent: platform/107d508500.gpio, gpio-brcmstb@107d508500:
 gpio-480 (-                   )
 gpio-481 (2712_BOOT_CS_N      |spi10 CS0           ) out hi ACTIVE LOW
 gpio-482 (2712_BOOT_MISO      )
 gpio-483 (2712_BOOT_MOSI      )
 gpio-484 (2712_BOOT_SCLK      )
 gpio-485 (-                   )
 gpio-486 (-                   )
 gpio-487 (-                   )
 gpio-488 (-                   )
 gpio-489 (-                   )
 gpio-490 (-                   )
 gpio-491 (-                   )
 gpio-492 (-                   )
 gpio-493 (-                   )
 gpio-494 (PCIE_SDA            )
 gpio-495 (PCIE_SCL            )
 gpio-496 (-                   )
 gpio-497 (-                   )
 gpio-498 (-                   )
 gpio-499 (-                   )
 gpio-500 (PWR_GPIO            |pwr_button          ) in  hi ACTIVE LOW
 gpio-501 (2712_G21_FS         )
 gpio-502 (-                   )
 gpio-503 (-                   )
 gpio-504 (BT_RTS              )
 gpio-505 (BT_CTS              )
 gpio-506 (BT_TXD              )
 gpio-507 (BT_RXD              )
 gpio-508 (WL_ON               |wl_on_reg           ) out hi
 gpio-509 (BT_ON               |shutdown            ) out hi
 gpio-510 (WIFI_SDIO_CLK       )
 gpio-511 (WIFI_SDIO_CMD       )
Try changing these original lines in pisound-btn.c:
static int gpio_is_pin_valid(int pin)
	return pin >= 0 && pin < 100;
to:
	return pin >= 0 && pin < 1000;
And:
static int g_button_pin = 17;
To:
static int g_button_pin = 416;
Then run make && sudo make install again.
It works well! Thank you!!
Happy New Year!
2024년 1월월 5일 (금) 11:00 오후, Giedrius via Blokas Community <[hello@blokas.io](mailto:2024년 1월월 5일 (금) 11:00 오후, Giedrius via Blokas Community < 작성됨:
