Pimidi + lcd 2004
Hello everyone,
do you think that I can chain the pimidi and a LCD 2004 with a I2C interface ? they are both sharing the same pins. And the I2C protocol supports daisy chains. I don’ t see blocking point here but I might be wrong…
Thanks
Yes, it should not be a problem - just ensure that they use different I²C addresses and that there’s no GPIO conflict, see the sel rotary switch documentation here and the GPIO pins used by Pimidi.
A nice tool to use to see if all I²C devices are detected as expected is this one:
i2cdetect -y 1
(sudo apt install i2c-tools if not found)
You should see “UU” on Pimidi’s address, as the address is in use by its kernel module, and the address of your LCD.
Thanks for the feedback. I will experiment this (still waiting for my pimidi to arrive :slight_smile: ).
I have concerns relative to the fact that the I2C bus is shared with PiMidi and the LCD. I might experience bottleneck on the I2C bus and jitter wrt MIDI transmission… but let’s see.
It depends on your code - try making your screen updates in bursts, only when something changed, releasing the shared bus for other devices as much as possible. Give 400kHz baud rate a try, to see if the LCD manages updating at that rate, otherwise use 100kHz. I didn’t find the baud rate specification of the LCD anywhere.
Hi, Thanks for the advice. I do not have the LCD spec neither. I will try.
