Hey guys! As the Midihub birthday is coming up this weekend, we’re releasing a new feature we’re sure everyone will appreciate . Introducing the real-time MIDI Monitor!
The MIDI Monitor shows all the data being processed and produced by the currently selected pipe, as well as provides a BPM estimate based on the recent Clock events. Filters can be set up to hide irrelevant events.
Ok, uninstalled Editor; Installed previous version; flashed FW to the Hub; uninstalled older version of the Editor; installed new version of the Editor.
Presets are gone.
Make sure to save your presets to files for later re-import.
There’s a confirmed issue with importing memory backups into Midihub, we’ll get it fixed soon. If you’ve encountered the issue, please send me the .mhd file via PM and I should be able to recover it for you.
The firmware auto-update process works ok to move the memory contents to the new version.
Brrrrwwwwaaaaaghghgh!! Thanks guys. This is awesome. I’m 100% certain this will make things so much easier for me. Cant wait to get stuck in this evening.
And I LOVE that the monitor pane can be popped out to a separate window. Put on my second monitor and not sacrifice any screen real estate for pipelines and properties.
With a simple patch installed to test the monitor USB A/B/C/D to OUTPUT A/B/C/D driven by 4 different clips from Ableton via USB - nothing appears on the monitor. In fact fiddling around for a couple of hours nothing has ever appeared on the monitor. Selected it on / off many times.
Hi - many thanks - I selected within the settings of the midi monitor, all off for both input and output and it worked. Even though they were all off anyway?
And yes didn’t get input monitoring initially, my default position, which I hadn’t tried until you suggested it - when above applied, all fine!
