Converting to virtual loopback
Hello ALL:
Trying to update to version 1.14 before moving forward. How would I convert loopback in this patch so that I can remove the midi cable from in/out D:
11:30sus worx.mhp (1.4 KB)
Thanks Much for your help!
Peter
Follow the flow @pje !
As you said , your original had:
  • “midi cable from in/out D”
  • all the messages going to D-OUT are in line 1
  • Five (of the 7) mappings use D-IN as the source
    these are the ones you want to change
So now (using 1.14.0) you:
PS. the Channel Remap was put in for Loopback safety reasons.
When you’ve got the above working, you can lose this if you Edit your “flipped” CCs to the original incoming channel at A-IN
YES! Even I understood and executed that.Thank you. I will start new subject for the next issue…
