Struggling with ttymidi/MIDI hat
I recently got a Domoshop Slim MIDI HAT for my Raspberry Pi 3B and am struggling to get it to work. I’ve installed ttymidi and the device seems to be recognized (shown as client 129 ‘MIDI’ below).
The HAT is connected to my desktop computer’s MIDI interface with MIDI Monitor on, and cannot get any output, either with a .mid file (aplaymidi -p 129:1 x.mid) or if I try with Pure Data. Patchage shows the connection as existing, and it updates in real time if I make the connections in Terminal with:
aconnect 'Pure Data:1' MIDI:1
aconnect MIDI:0 'Pure Data:0'
I’ve got /boot/firmware/config.txt and /boot/firmware/cmdline.txt both edited as recommended.
I tried uninstalling and reinstalling ttymidi, yet nothing is happening. (Since I’m on arm64 I installed the Bullseye package)
The stupidest part is I briefly was able to receive signal on the Pi when I first set it up. I’m not sure what I did then or what made it stop working (it literally just stopped as I was simply sending CCs from my desktop computer.)
I’ve read this thread:
here is the output for aconnect -l:
client 0: 'System' [type=kernel] 0 'Timer ' Connecting To: 147:0 1 'Announce ' Connecting To: 128:0, 130:0, 147:0, 134:0 client 14: 'Midi Through' [type=kernel] 0 'Midi Through Port-0' Connecting To: 130:0[real:0] Connected From: 130:0 client 129: 'MIDI' [type=user,pid=613] 0 'MIDI In ' Connecting To: 130:0[real:0], 133:0 1 'MIDI Out ' Connected From: 130:0, 133:1 client 131: 'RtMidiIn Client' [type=user,pid=841] 0 'TouchOSC Bridge ' Connected From: 130:0 client 132: 'RtMidiOut Client' [type=user,pid=841] 0 'TouchOSC Bridge ' Connecting To: 130:0[real:0] client 133: 'Pure Data' [type=user,pid=1088] 0 'Pure Data Midi-In 1' Connected From: 130:0, 129:0 1 'Pure Data Midi-Out 1' Connecting To: 130:0[real:0], 129:1 client 147: 'PipeWire-System' [type=user,pid=929] 0 'input ' Connected From: 0:1, 0:0 client 148: 'PipeWire-RT-Event' [type=user,pid=929] 0 'input '
Given that you had ttymidi working before and something went wrong, it could be a physical hardware issue. I’d recommend reaching out to the manufacturer of it for support. As Patchbox OS is based on Raspberry Pi OS, there shouldn’t be anything specific to PbOS - every Linux troubleshooting steps should be the same for it.
