I found a discussion about desoldering the button[1] which talks about soldering to GPIO 17 and ground instead. I like this idea but, there is no easy access to GPIO 17. I know I can solder to the nice ling header pins on the pisound but when doing that 100 times I am fairly certain there is a high probability of soldering to the wrong pin.
Would it be possible to provide a pad that exposes GPIO 17, or change you 2x7 extension header to a 2x8 and provide access there?
Also, does the button have pull-up resisters in it or do you simply use the available resisters in the GPIO on the PI?
Thanks,
Claude
