Hey guys, as part of building the Patchbox OS image, we’ve built some newer versions of audio software. If you have installed Pisound software, then you have the Blokas apt server already configured! (if not, just run these commands to set it up)
If you’d do sudo apt-get update && sudo apt-get install puredata you’d receive the new 0.49 version of Pure Data with infinite undo!
Same for these updated packages:
jackd2sonic-pisupercollider
There’s also Pianoteq Standard Trial (physically based piano modelling synth) available to be installed:
pianoteq-standard-trial
