I’ve had no problem running the 14 PD patches from the Pisound collection using my Android app. But I can’t seem to get the app to recognize any patches via USB. I’ve tried a “puredata-patches” subfolder on the thumb drive, as well as just placing patch as “main.pd” in the main folder of the drive.
I’ve updated Pisound and confirmed that PD was installed. Could it be an issue of formatting the drive? I’m running Raspbian on the Pi, but pulled PD patches onto the usb via my Mac desktop.
I’m sure it’s something simple, but I couldn’t figure it out based on related posts. Thanks in advance for any help!
Are they available in /media/pi/puredata-patches, or is there more folders inside ‘pi’ (as in /media/pi/…/puredata-patches)? In other words, what’s the full path to puredata-patches on your usb drive?
I tried this path and other variations with no luck.
Ended up reflashing my SD card, this time using the Mod Duo image. I was able to begin configuring the Pi, but I’m stuck with a Warranty message.
Unfortunately I know of no good way to copy and paste the msg from the Pi without leaving terminal…
Then you may easily copy the screen output as needed.
Sorry, I meant to find out what was the full path to puredata-patches on your system, I suspected the USB storage was getting mounted to a place where our usb_import.sh script does not expect it, and therefore fails to import the patches.
