I’m wondering if anyone has managed to have Sunvox (the modular synth and tracker tool) running on Patchbox OS?
I’m on a Raspberry Pi 4. If I use the default Raspian OS, Sunvox works fine. But on Patchbox, when I launch it by double-clicking the file, it doesn’t do anything.
I tried to launch it via the console and got this error:
patch@patchbox:~/Downloads/sunvox/sunvox/linux_arm_armhf_raspberry_pi $ ./sunvox
./sunvox: error while loading shared libraries: libSDL2-2.0.so.0: cannot open shared object file: No such file or directory
What’s that libSDL2 thing and how do I get it?
Is that something I can install via the apt thing? If so, what would be the command?
(I’m fairly new to Linux. Sorry if it’s a very basic question.)
As for miRack, I think it might be incompatible with the RPi 4. I tried it on regular Raspbian (not Patchbox) and have the same error. I will try to contact their developer.
Update: I managed to have miRack running. I installed a bunch of packages until it worked. I’m not sure which one made it working. I’m just glad miRack is working on Patchbox.
The one command that made it work was this one: sudo apt install libgles2-mesa-dev
I don’t know which of its multiple dependencies was actually the one required.
The following additional packages will be installed:
libegl-dev libgl-dev libgles-dev libgles1 libglx-dev libpthread-stubs0-dev
libx11-dev libxau-dev libxcb1-dev libxdmcp-dev x11proto-core-dev
x11proto-dev xorg-sgml-doctools xtrans-dev
Nope, just libgles1 is not enough. After a few more trial and error, it seems libgles-dev is the required one to get miRack working. So, for anyone reading this, you need sudo apt install libgles-dev
I’m still waiting on a reply from miRack’s dev for a better answer, but it seem the project has been abandonned
So, for anyone reading this in the future, here’s the recap answer:
For Sunvox, you need to install libsdl by doing this:
For miRack, you need to install libgles. The basic package is not enough, it seems we need the dev package. So you need to do this: sudo apt install libgles-dev
