Little question, since I ditched the google Android from my phone and now have the open source one (which does not support the Play store). Is there some way to get the app without going through Yalp Store?
Would a downloadable .apk package work for you? What OS are you running on your phone?
FP Open, which is basically a de-googlized Android for the Fairphone2. So yes I guess an apk would work, of course I’d have to update manually each time an update comes up, but I’m ok with that.
I can’t remember if the Pisound app is open source, but if it is, you might want to check F-Droid, that seems to be the most trusted alternate app store for open source apps on Adroid.
Ok, I’ve uploaded the apk here: https://blokas.io/pisound/app/com.blokas.pisoundctl.v1.02.apk
Also updated the documentation here: https://blokas.io/pisound/docs/Pisound-App/#android
thanks a lot!!!
Install worked perfectly! Thanks again!
