Pi sound audio output stopped working - resistor MIA value?
Hi Pisounders,
TLDR: Can anyone tell me
the resistor value I have missing from my pisound board in the attached picture? (circled in red)
I am guessing it is 220 Ohm but if any could check to see if it is black with a label β€œ221”.
Background:
I have a problem where I have lost audio out. Sound IN appears to work. I can capture with audacity etc and can see clipping LED turn on. I tried all the advice on the forums testing with without the modep/patchbox image but nothing work. Pisound appeared to be working normally.
I tracked the signal trace from pin 40 of header to the Din pin 14 of the PCM5102A which appeared OK having 220Ohm but while I was checking I saw empty solder pads :scream:
I was running Modep via PatchBox in Pi4+Pisound and it was amazing, like the sound and latency was incredible … and then
I decided to try it with a Pi3 as the Pi4 was kicking some serious heat(no fan) while I built a fan and modded the 3D enclosure.
Searching the board it appears I have knocked a resistor off the board, but before I solder a new one on wanted to verify the value. I did see a pic here pcb picture but it is a little fuzzy to be sure.
Any help would be appreciated so I can get back using this.
Yes, it’s a 0603 220 Ohm resistor.
Thank you so much,
Soldered a new resistor on and back in business.
Robert
