Ok, I tried the same - saving an empty pedalboard, and got the same errors as you do. But at least saving and loading a pedalboard that does contain some plugins seems to work fine.
Is there still an issue with the Pimoni Fan Shim and the Pisound. It seems like following the instructions on then Pimoni page " a script to install a daemon (a service that runs in the background) that runs the fan in automatic mode, triggering it on or off when the CPU reaches a threshold temperature, with a manual override via the tactile switch." should be able to get around this. Is this what folks have been using? TIA
it’s been a while since I last used my py, and recently I encountered the same problem as before, so I looked at the logs as you told me, but I don’t understand why, I have the impression that there is no recent eventcrash.log (1.3 MB) .
Can you tell me what’s your point of view please?
As the Raspberry Pi’s system clock gets synchronized to network time only some time after boot, it’s a bit difficult to follow the timeline, so just to be safe, earlier logs might help.
the problem just happened when i was looking at youtube video… these are the log , i give youcrash11.log (1.3 MB) crash21.log (88.3 KB) crash31.log (257.0 KB)
This indicates that Jack backend, responsible for audio, started to have some issues, most likely buffer underruns. This can happen if the system is overloaded. What are the Jack backend settings you’re using? Try increasing the parameter values for more stability.
