MODEP and Raspbery Pi 4
with the newest Patchbox image and a new RPI4 I do not get any USB port, mouse & keyboard to work.
If I do “sudo rpi-update” the USB ports and USB devices are working fine with the updated kernel 5.4.51-v7l+.
I’ll get the Pisound in a few days and because the setup via ssh is working I’m looking foreward to use everything as intended but of course working USB ports are desired.
I had no success to use a different compiled kernel - via this description:
https://madskjeldgaard.dk/posts/raspi4-notes/#install-a-real-time-kernel
I had succes to compile and boot this kernel but I assume the kernel has to be compiled in regard to MODEP?
Is it possible to use a different kernel with Patchbox/Pisound and if so how to do it?
@Giedrius these MODEP generator scripts you are writing about here:
is there more information about the usage and/or the kernel build process in general?
Could using this rt patched kernel 5.6 work? :
https://mirrors.edge.kernel.org/pub/linux/kernel/projects/rt/5.6/patch-5.6.19-rt11.patch.gz
https://aur.archlinux.org/cgit/aur.git/tree/parameters.patch?h=snd-usb-audio-lowlatency-dkms
links found here:
https://www.raspberrypi.org/forums/viewtopic.php?t=250927
cheers
